| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Premium Member ![]() | So.. this will be the second time I'm trying to get my rear diff sealed. The first time I used a Kaaz supplied gasket and blue rtv and had leaks. This second time I used an oem gasket with minimal RTV. Cover is not warped. All bolts torqued slowly and properly.And I even let the damn thing sit over night but it still ended up leaking two days later. I tried looking in the FSM but cannot find a section where it talks about a rear diff cover gasket procedure. And I tried searching here but can't find anything. What I need to know is what you guys have done to get the Rear Cover to seal on there properly. I am thinking of going with straight Permatex ultra black or even the gear oil version of permatex if I can find it, with no paper gasket. I wanna make sure this is ok to do or do I need to spend another $30 on another oem gasket? FYI I am running a kaaz two way with Kaaz powertrain oil. Thanks for any help in advance. |
| Sponsored Links | |
| | #2 |
| Zilvia Addict ![]() | are you sure its not leaking out of the breather? no pressure in the pumpkin, sealing it should be a no brainier not much to go wrong. maybe input or out put shaft seals are warn, not common but it could happen. Id clean the whole diff.. and check. I reuse that gasket in the back, and put ultra gray on the other side a bunch of times. never a leak.
__________________ sold my soul to the devil... w/ an rb26 |
| | #3 |
| Premium Member ![]() | Input and output shafts are all clean. One spot on the side of the diff is the only place it was leaking from this time. As far as the breather I thought that too, I checked it and it was dry only wet in one spot on the side of the pumpkin. I think maybe more RTV and the hardcore Black not blue stuff that I was using before may be called for. I am just making sure I'm not going nuts here and missing something. This is gonna be the third time I gotta pull this thing out and I got an event to go to next Saturday.(That's life I guess.) |
| | #4 |
| Post Whore! ![]() | |
| | #5 | |
| Zilvia FREAK! ![]() | Double check that you got the old gasket completely off the old cover and diff surface. I had a similar problem and once I had everything clean and re-gasketed it sealed up just fine.
__________________ Suck my balls 8====D (You are here, you know who you are) Quote:
| | #6 |
| Post Whore! ![]() | RTV only. I've never used anything else.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #7 |
| Premium Member ![]() | Thanks for the replies guys. I picked up some of the Ultra Grey high Torque RTV sealant. And i am gonna try this out, Not gonna mess with the paper gasket anymore. I just wanted to make sure I could get rid of the paper gasket and just use RTV. It's infuriating to have to be taking this thing out for the third time and redo everything so hopefully this will work, I'll keep everyone posted. |
| | #8 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
