Old 10-24-2009, 09:57 PM   #1
r33, 32 seats in s13 mounting bracket weld?
anyone got pics of the mounting bracket that doesn't match up to the mounting points? i would like to do it but would like to see what others have done.
Monkey Boy is offline   Reply With Quote
Old 10-26-2009, 01:56 AM   #2
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Seriously, did you even try to mount it to see what you have to do? You weld in a 1.5-2" tab with a hole in it to put the stock bolt thru. If you're really lazy, get a big/thick ass washer to wedge the stock bracket in place.
Old 10-26-2009, 06:52 AM   #3
In time-out for misbehaving.
Send a message via MSN to yokotavia
i had a r32 seat rail in my s13 and i never used the 4th bolt.
never had any problems, even after getting tboned in the driver side of the car. seat never moved
3 out of 4 is enough.
yokotavia is offline   Reply With Quote
Old 10-26-2009, 01:45 PM   #4
yes they are mounted. it is just that the seller i bought it from for whatever reason cut the nonmatching tab on the drivers side right after the whole, where the tab bends from the rail. the floor mount hole is actually like elevated above the car floor and now the seat mount is resting in front of the floor mount, so it sinks down below the floor mount so now my seat is uneven. hope that makes sense. like you guys said it usually sits right at the edge of the floor mount but since it is cut it sits below and in front.
seat tab> \ /-\<floor bolt in
Old 10-26-2009, 05:31 PM   #5
yeah i understand that. i had carpet in the 13 that i had an r32 seat rail in...so it was dam near even
Old 10-26-2009, 05:56 PM   #6
i got my carpet still in too. since the rail mount is cut and it sinks low it made the hole in the carpet bigger where the floor mount is. not to happy about that.
Old 10-26-2009, 08:02 PM   #7
lol who cares its an s chassis.
you walk out of a bar leaving with 3 out of 4 girls, thats good enough for me.
Old 10-26-2009, 08:08 PM   #8
RedLine SlideWays
s13 @ fullboost's Avatar
^^ that's a good one almost sig worthy
Team RedLine SlideWays
www.aigraphix.com/wordpress
Just another rough day at the office.
Old 10-26-2009, 08:13 PM   #9
witty to bad you can't read. the tab that does not match is also cut so it sinks below the floor. that makes the seat UNEVEN so I HAVE TO DO SOMETHING about it.
Old 10-26-2009, 10:11 PM   #10
make some measurements. weld on a bracket. this thread sucks
Old 10-27-2009, 01:15 AM   #11
projectRDM's Avatar
Seriously. You have a bolt hole. You have a rail. Make a bracket that connects them. It's 60 seconds with a piece of flat stock.
FORMERLY R240NA
Old 10-27-2009, 01:22 AM   #12
Tint Master
besTint's Avatar
Trader Rating: (31)
Send a message via AIM to besTint
simple fab. weld a tab, same size about 2-3 inches out. drill a hole size of the bolt. done deal. good as oem.
Best Tint Auto Center
10650 Beach Blvd.
Stanton, CA 90680
714-828-8800
Tint specials for all local Zilvia members
(240sx only) $130, any shade, all 5 windows.
besTint is offline   Reply With Quote
Old 10-27-2009, 01:32 AM   #13
well i don't know how to fab or weld. consulted with my friend and he helped me with it. i cut off the bracket from a s13 seat then we took off the bracket on the r33 all the way to the rail and then welded on the s13 bracket to the rail.
i couldn't add on a tab because it was cut at the bend and it looks like it was melted off, was not a clean cut.
it may seem easy to you guys but to someone with no welding experience it is hard to figure out especially since i want it so it won't break off.
SEO by vBSEO 3.3.0
