| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| sr rwdtop -- t28 issue Before i did this i had a t25 fmic - afc2 was off - car smoked couple time and would have a perfect idle but would not go over 3k rpms changed turbo- to s14 t28 now-- will rev all the way through- but wont hold a idle - only way to keep idle is to use carb spray any ideas? intercooler pipeing holds air throttle seems to be working correctly - tps-- just seems like a fuel issue - changed - fuel pressure regulator- fuel filter could it be just a bad pump? | |
| Sponsored Links | |
| | #3 |
| Premium Member ![]() | oem fuel pump or aftermarket, check for boost leak
__________________ 18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
| | #4 |
| got it partially fixed -- changed walboro out to another walboro -- then changed the maf -- now -- #2 and rear #4 injectors arent firing again -- grr have always ran 91 in the car -- car sat in the garage for over a year-- then started drove it a month then the t25 went now running into these issues | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
