Old 10-13-2009, 10:08 PM   #1
marcobleedsblue's Avatar
power window problem!
ok so i was having problem with my windows.. they would go up and down but the fusible link kept blowing.. and bow the passenger side rolls up and down but the drivers side doesnt.. i can here a lol click wen i push down the button to put my drivers side window down but nothin happens... heelppp raining season is coming!! lol
marcobleedsblue is offline   Reply With Quote
Old 10-14-2009, 01:17 PM   #2
ghost's Avatar
Check your switch with a test light or voltage meter, make sure it has ground, 12v, also make sure that when the switch is pressed down, that your motor is receiving signal. If it isn't the switch is bad. If it is, then the motor may be going. But due to the fuse going regularly it sounds like a short.
1993 180sx Type III
219whp, 235ft/lbs tq
ghost is offline   Reply With Quote
Old 10-14-2009, 06:23 PM   #3
so what you're trying to say is that your driver side window works, but every once in a while the circuit breaker trips and your driver side window will stop working for a couple minutes?
ConceptS14 is offline   Reply With Quote
Old 10-14-2009, 08:52 PM   #4
could be the power window amplifier, take your door panel off reconnect your window switch tap on the white box while working the switch see if it works
aguadilla is offline   Reply With Quote
Old 11-03-2009, 12:23 AM   #5
M11's's Avatar
+1 if it clicks when you push down switch probably the switch thats what was wrong when mine went out
M11's is offline   Reply With Quote
SEO by vBSEO 3.3.0
