| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia Member ![]() | custom braided brake lines? im looking to get some lines made and i dont know who or where to look. i need something to go from my brake booster to about half way across the engine bay, i need to re-route the current stock set up for clearance issues with my top mount set up, any suggestions?
__________________ need 4x114 rims w/ tires and cheap sus! |
| Sponsored Links | |
| | #2 |
| Zilvia Junkie ![]() | Just make your own. All you need is a bender and a flare tool. Summit SUM-900675 - Summit Racing® Tubing Benders - Overview - SummitRacing.com http://www.summitracing.com/parts/SUM-900311/
__________________ |
| | #3 | |
| Zilvia Member ![]() | Quote:
anyone know what the thread pattern is for the brake booster? i need to run a 90 right out of it. and a tight 90 so it would need to be a fitting... is it universal?
__________________ need 4x114 rims w/ tires and cheap sus! | |
| | #4 |
| Premium Member ![]() | If you were local, I would suggest stepping into Earls or Baker Precision they would make you the lines on the spot
__________________ S-Chassis/Z32 Rear Upright Spherical Bearing Group Buy |
| | #5 |
| Post Whore! ![]() | I have full braided brake lines from cylinder to caliper. If you're local just cut off the fittings from the hardline and take it in to get the correct thread pitch. Or you can bring them the master cylinder. |
| | #6 | |
wow cant believe i didnt think of that.. thanks . /thread.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
