| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Premium Member ![]() | bad alternator? need help. car wont start without a jump. everything works. light,radio,windows. but car wont start on its own.. KADE BTW. alternator? ![]() sooomeone |
| Sponsored Links | |
| | #3 |
| Zilvia Junkie ![]() | take off starter(be sure to disconnect battery first) take it to auto zone and theyll test your starters voltage and if you need one then buy one there problem soved
__________________ **CoUpe LOve** #3_4POINT CUSCO CAGE4 SALE! |
| | #5 |
| Zilvia Addict ![]() | if its your alternator i have one off a s13 for sale $15 ![]() |
| | #6 |
| Zilvia Member ![]() | make sure all the wires going into and around your distributor are all tight. especially then single wire going to the coil thing., |
| | #8 |
| Keep it simple My S14 did this after sitting for months. Turned out to be corrosion on the battery terminals that caused the issue. I suggest starting with the simplest things first. Clean your battery connections.
__________________ "A poor fool indeed is he who adopts a manner of thinking for others!" | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
