Old 10-05-2009, 09:23 PM   #1
fuel pump for sr20
i was wondering what fuel pump can i run for sr20? i wanna turn up my boost and i heard the stock one isnt going to cut it, i want something better but not a walbro i am a student and i dont got the money for that. i heard 300z will work but are there any local cars? besides g20 since it should be a weaker pump since it is a sr20 de not det?
PhilipJdm is offline   Reply With Quote
Old 10-05-2009, 10:17 PM   #2
300ZX TT will work it's 260LPH and it's goes for 299$ last time i checked. The R33 GT-R pump is th same as the 300ZX pump.
You can go with sard FP. there is one that 265 LPH And the big one is 280 LPH.
Stock Sr i'd stay away from walbro...Alot of faliuer stores been floating around.
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 10-07-2009, 01:14 AM   #3
okay so walbro not good? and would the 300z non tt do the job? or it isnt strong enough?
Old 10-07-2009, 07:23 AM   #4
KA-T FTW
punxva's Avatar
Send a message via AIM to punxva Send a message via MSN to punxva
you can just go ahead and get a walbro, they just flow a little bit less than the 300z
-Punxva
Originally Posted by ThatGuy View Post
Cars are not MEANT to "run into shit".
Stupid fucking drifters.
Old 10-07-2009, 08:11 AM   #5
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
If you cant afford to get a Walbro, you wont be able to afford a Z32 TT pump. I'd be very very wary of running a used fuel pump.
Old 10-08-2009, 02:07 AM   #6
so i should go for a walbro?
Old 10-08-2009, 02:12 AM   #7
lost240soul's Avatar
i have a walbro pump if u need one 50 bucks pick up..it was used to start up my car after i swapped but thats it never been used after that then i just pulled it out... i heard a supra one works too but also kinda pricy
lost240soul is offline   Reply With Quote
Old 10-08-2009, 07:01 AM   #8
Just buy a new walbro...go for less than $90 on e-bay...
Old 10-08-2009, 11:01 AM   #9
lilrusty's Avatar
dude no offense but if you have a car with an sr20 you sould be able to afford at least the walbro pump. all the other ones are more expensive if you are on a budget. i got my walbro for like 80 bucks brand new...
lilrusty is offline   Reply With Quote
Old 10-08-2009, 11:07 AM   #10
The thing with walbro's failure: Don't run on a near empty tank. According to some research on the forums, Walbro in-tank pumps use the gasoline as insulation. So driving around on a tank with no gas= no insulation= pump failure. Otherwise they're just fine.
For Sale: sr head, internals, etc... PM ME!
VNG704 is offline   Reply With Quote
Old 10-08-2009, 04:38 PM   #11
umsports's Avatar
Send a message via AIM to umsports
Walbro will be just fine. We sell them for $100 with the install kit.
1998 RB26DETT 240SX 810whp@28lbs
1995 KA-T 530rwhp/455wtq @ 25lbs
umsports is offline   Reply With Quote
Old 10-08-2009, 04:46 PM   #12
HYPNOTIK's Avatar
That's bullshit. Someone's fake walbro stopped working and they looked down and realized they had a 1/4 tank of gas so they made up a bullshit theory and now everyone is paranoid about walbros.
I live literally 3 miles from the sun and don't get gas until my light comes on, my pump hasn't died and this is the second car it's been in.
Get a real walbro and forget about it. I would pay $120 to make sure I got a real pump from somewhere like Summit before I paid $80 on ebay for a most likely fake one.
HYPNOTIK is offline   Reply With Quote
Old 10-08-2009, 07:11 PM   #13
oh okay, well i thought walbros go for more than 120 O_o thats why.
Old 10-21-2009, 12:05 PM   #14
walbro ftw
nissanfreak317 is offline   Reply With Quote
Old 10-21-2009, 06:00 PM   #15
Sileighty_85's Avatar
Agreed
Ive ran my Walbro on an 1/8 of an tank for a while now
Just make sure your tank is clean and your strainer is correctly installed.
My buddy ran a walbro with a drity strainer for like 2 weeks, cleaned the tank and replaced it and ran fine again.
Just buy it from an real shop. Phase2, Enjuku...ect
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 11-16-2009, 07:47 AM   #16
sorry for aside from the topic but im about to replace my fuel pump with walbro.any suggestion for size? bc im using s14 with blacktop sr20 and between 1 to 10 how hard do u think to install from oem to aftermarket fuel pump? appreciated
westly7 is offline   Reply With Quote
Old 11-16-2009, 02:02 PM   #17
umsports's Avatar
Not difficult to install at all. Takes maybe an hour tops. We sell the Walbro 255lph w/ the install kit for $100 and have never had any customer issues with them.
Old 11-16-2009, 04:36 PM   #18
FRoSt415's Avatar
Send a message via AIM to FRoSt415
This is true but that is how some gas tanks work. The gasoline cools down the pump and prevents it from getting hot and prolongs the pump life. You can run your car with the gas light on but your pump will eventually burn out faster than if you had some gas. This will increase the likely hood of it happening but does not mean it your pump will malfunction, all parts on cars break or wear out. Please don't blame a brand name pump as well this can happen to any fuel pump designed like this.
i would call it a 4 all u need is a adjustable wrench or i would recommend having the proper size sockets but it can be done in less then an hour.
Tools assorted deep sockets
pliers for removing gas line and clamps
remove panels to access the gas tank. remove tank cover, remove old pump and lever and replace with new pump and add lever. make sure when u put the gas tank cover on that the rubber gasket is even and secure.
FRoSt415 is offline   Reply With Quote
Old 11-16-2009, 05:05 PM   #19
g6civcx's Avatar
This is common on all in-tank pumps, not just the Walboro.
The design on the S13 tank isn't so good when you get below 1/4 tank based on the location of the pickup in relation to the tank. It's just a design flaw at the factory.
Ditch the stock tank and get a fuel cell.
SEO by vBSEO 3.3.0
