Old 10-01-2009, 11:30 PM   #1
Windsheld wiper is going crazy and wont stop
The topic pretty much explains what my problem is.
The only way for it to stop is if i turn off the car and then turn it back on. It only does it sometimes not all the time so what can it be?
oh yea i have an s13
240sxvaj is offline   Reply With Quote
Old 10-01-2009, 11:34 PM   #2
its a 240..
240sxfamily is offline   Reply With Quote
Old 10-02-2009, 12:41 AM   #3
Originally Posted by 240sxfamily View Post
its a 240..
hahaha besides that
Old 10-02-2009, 12:45 AM   #4
e1_griego's Avatar
Rear wiper?
One of the wires is most likely cut on the passenger side at the top of the hatch. Just fixed my cut wire a few weeks ago.
Old 10-02-2009, 12:47 AM   #5
give us more info dude, what wires front or does your car have a hatch wiper, cant really help without info :P
1995 240sx SE (current)
Ceepo is offline   Reply With Quote
Old 10-02-2009, 05:24 AM   #6
projectRDM's Avatar
Three parts in the wiper system, switch, amp, and motor. Break out the FSM and trace signal from each, one of them is bad and feeding current when set to 'off'. My guess is the amp, it's typically the culprit.
FORMERLY R240NA
Old 10-02-2009, 07:26 AM   #7
g6civcx's Avatar
Could be the autoreturn and stop feature. When you turn off the wipers, the wipers have a pin that shows ground when the wipers are away from base. The wiper amp moves the wipers until the wipers are back at base and then stops.
It looks like this pin is damaged or the circuit is shorted.
Old 10-02-2009, 11:23 AM   #8
sorry for the shitty info.
its for the front wipers, i dont have back wipers. everytime i turn the switch on it turns on and then when i turn it off it goes on forever, but if it doesnt forever it will wipe for 3 more times and then turns off.
Old 10-02-2009, 12:16 PM   #9
Wiper Amp.. i had the same problem.. gone through 3 of them already
Dorimonster.blogspot.com
qt_240 is offline   Reply With Quote
Old 10-10-2009, 11:34 PM   #10
where is the wiper amp located?
Old 10-11-2009, 01:08 AM   #11
Violent Running Asshole
Om1kron's Avatar
Send a message via AIM to Om1kron
Originally Posted by projectrdm View Post
three parts in the wiper system, switch, amp, and motor. Break out the fsm and trace signal from each, one of them is bad and feeding current when set to 'off'. my guess is the amp, it's typically the culprit.
zing!!!!!!!!!!!!!!!
Wayne T. Edwards
Violent Running Tribe News Blog <---Peep This
Old 10-11-2009, 08:32 AM   #12
projectRDM's Avatar
Under the hood, opposite the wiper motor.
FORMERLY R240NA
Old 10-11-2009, 09:13 AM   #13
g6civcx's Avatar
Green mystery box next to the clutch master.
Old 10-11-2009, 12:13 PM   #14
I was thinking that was it. I guess i gotta head out to the junk yard.
Thanks for all the help zilvians
Old 10-12-2009, 03:18 PM   #15
I had the same exact problem to the T lol. It started when my harness(DS fender) got cut open from not being relocated and my car being low. I fixed those wires and it fixed the problem.
omgshawn is offline   Reply With Quote
Old 10-12-2009, 06:12 PM   #16
Send a message via AIM to RB240Mike
+1 I've had that happen like 5 times... it's most likely your problem
RB240Mike is offline   Reply With Quote
Old 11-04-2009, 01:13 AM   #17
has anyone had success repairing this amp?
yukon is offline   Reply With Quote
SEO by vBSEO 3.3.0
