| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Front Tension Rod Bolts I have a pair of Footwerks front tension rods for my 1998 240SX. They never came with any hardware. I see that my stock ones are pressed in, so i'm confused as to what bolts I need. I searched on here and never got much info, so i'm guessing it's something simple, but i'm still going to ask. Thanks for any info. | |
| Sponsored Links | |
| | #2 |
| Zilvia Addict ![]() | Anything Grade 8.8 will work. You can use grade 10 as well. Just take a rod with you to the local hardware store and find something that fits snug in the predrilled holes.
__________________ Built 95' S14.... |
| | #3 |
| Post Whore! ![]() | Or knock the OE studs out, press them in the new rod.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #4 |
| | #5 |
| Post Whore! ![]() | I've been doing it since '96. Works fine. But if you want to just buy a bolt, they don't have to press in, just make sure the bolt size is the same, IE 12mm. You don't want smaller bolts in there giving the rod room to flop around.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
