Old 08-09-2009, 04:54 PM   #1
deafmonkey7's Avatar
Send a message via AIM to deafmonkey7
s13 Power Door removal/install
Working on a vert replacing the heavy doors with coupe doors, both with power windows. Ont the outside there are the wires going from the door to the car. I cannot reach those wires. I need to know if I need to remove the dash, to get to the wires, to disconnect the two blue and white clips. I know the passenger side wires are longer than the driver side, I just cant see either of them inside the car! Is there something im missing, some kinda trick? or am I stuck removing the whole dash?
Who has replaced their doors!?!
My car is all apart right now and I need some help asap
deafmonkey7 is offline   Reply With Quote
Old 08-09-2009, 06:14 PM   #2
ok, never mind the driver side, just got that done... but I still cant see where passenger side wires lead? Do I still need to take of the dash?
Old 08-09-2009, 08:51 PM   #3
projectRDM's Avatar
Drop the glovebox.
Or, remove the harness from the convertible door, then install it in the coupe door.
You have to do that on the driverside, the window amp is not located in the door on convertibles. Hopefully you noticed that before you swapped it all out.
FORMERLY R240NA
Old 08-09-2009, 10:46 PM   #4
lol, ya I was scratching my head on that one. Couldnt figure out what that box was on the door, and later found out that plugs and wiring were different.
Did drop the glovebox out, still cant see it.
So now my question is, how the hell do you get the harness out of the door?
Old 08-09-2009, 10:49 PM   #5
[JEFE S14]
GSXRJJordan's Avatar
Send a message via AIM to GSXRJJordan Send a message via MSN to GSXRJJordan
If you pull the door panel off, and disconnect the plugs from the inside, you can pull the harness out of the door. Done it tons of times.
TEAM SUS*PECT is alive.
www.JordanInnovations.com
Old 08-10-2009, 12:30 PM   #6
thanks jeff,
Old 08-10-2009, 11:47 PM   #7
Ok, got the wiring all figured out and everything works! wish I knew about the harness part earlier than later...
Now I have a new problem! yay
So I had the car up on jack stands and after the doors were on and working, I put the fenders and bumper back on and then pulled out the jack stands. Now the doors arent level with the latch anymore and need to moved up!@#%$!
So is there a way to adjust the doors without taking the damn fenders off?
Old 08-11-2009, 09:12 AM   #8
projectRDM's Avatar
Never install doors unless the car is on level ground (duh), especially on a convertible. The chassis is so dang flimsy it tweaks several inches.
You can reach in and loosen the hinge bolts through the wheel openings, but it is way easier with the fender off.
FORMERLY R240NA
door, removal, replacement
SEO by vBSEO 3.3.0
