| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Good deal? $340 for z32 brakes I found a guy selling front and rear calipers (26mm), front and rear rotors, front and rear pads, e-brake cables, and the e-brake assembly for $340. Only thing is, the e-brake assembly doesn't come with the back plate, I would have to get that separately somewhere. I'm going to pick everything up on friday hopefully but wanted to get some opinions on how good of a deal this is, if at all. Thanks. EDIT: woops, meant to post in general chat, sorry! Last edited by jeb1517; 08-05-2009 at 09:36 PM. | |
| Sponsored Links | |
| | #2 |
| Zilvia Addict ![]() Join Date: Nov 2006 Location: what I make up will fuck up your skinI pick the buck up and buck buck and buck buck again I will butt fuck your friend then suck up her twin I put the buck up to him then buck buck and buck buck and buck buck again suck nut you duck fuck Age: 19
Trader Rating: (2) | I think its a decent deal. I mean you are getting a complete brake swap. I paid 150 for just my fronts from a junkyard.
__________________ 92 vert converted 5speed and other little things |
| | #3 |
| He said he'll sell them for $100 more so the total would be $440. $200 of that is just for the e-brake assembly, $50 for cables, $50 for e-brake assembly and $100 for backing plates....this car's gonna make me broke... | |
| | #6 |
| Post Whore! ![]() | if the ebrake assembly doesn't come with the backing plate, then it isn't really the ebrake system. what is he giving as part of the "ebrake assembly" just the ebrake shoes, the springs and pins? 340 is not bad actually for front + rear calipers with rotors, pads, and ebrake cables. but as for the assembly, he should either keep the ebrake pins and springs, or sell everything with backing plate for a little bit more. breaking up the ebrake combination like that will make it difficult to complete, w/o sourcing the required parts seperately from junkyard or dealership.
__________________ i wanna be real chinese again |
| | #7 | |
| I was thinking about that but hadn't looked into it...how much does a full brake swap usually run? yes and no. the calipers and stuff are still the same price. The e-brake price went up because I thought it would be the whole assembly but he wasn't counting the backing plates. Quote:
| | #9 |
| motherfucker mike ![]() | this is a thread of retardation you should get whatever you NEED. when you upgrade brakes, either upgrade the entire system or leave it all stock. you do the front, rear and BMC. |
| | #10 |
| You have a GT in your avatar so I wouldn't expect you to understand. Buying rear brakes increases my price by 175%. I'd be happy to upgrade the entire system. How about you lend me the extra $280? | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
