Old 07-22-2009, 11:34 AM   #1
180f!xherUp's Avatar
5lug conversion
kk.... I did a 5lug conver on my s13... problem is my brake doesnt have pressure... No air in brake lines... do i have to upgrade my brake booster?
thanks
180f!xherUp is offline   Reply With Quote
Old 07-22-2009, 02:21 PM   #2
hOngsterr's Avatar
when i did mine my brakes were fine. they were untouched.
hmmm... just upgrade on ur brakes?
lol
89 FB DD/DELAYED PROJECT.
Old 07-22-2009, 02:40 PM   #3
palmdale_mob's Avatar
Have you worked with brakes before?
After you push in the piston on the calipers you have to pump the brakes to bring it back to normal
palmdale_mob is offline   Reply With Quote
Old 07-22-2009, 03:03 PM   #4
projectRDM's Avatar
thanks
There is no reason to touch the brakes, period. Take the caliper off, set it aside. What did you do, and why?
FORMERLY R240NA
Old 07-22-2009, 06:34 PM   #5
Shadowhunter's Avatar
I'm not sure what the brakes have to do with the 5 lug conversion unless you accidentally pinched a line or something.
Shadowhunter is offline   Reply With Quote
Old 07-22-2009, 11:28 PM   #6
hOngsterr's Avatar
my thoughts exactly
Old 07-23-2009, 07:01 AM   #7
Banned from the Marketplace
Trader Rating: (-1)
When u do a z32 or s14 5 lug and brake conversion most people get the s14 brake booster, I have heard people say that when they leave the s13 brake booster it becomes somewhat spongy but it still brakes fine, have u pumped ur brakes and check for leaks??
angelom88 is offline   Reply With Quote
Old 07-23-2009, 08:56 AM   #8
SOrry everyone... I was in a rush to post this thread... but this is exactly what my point is.... It brakes okay, but i have to push the pad most all the way down before it brakes... It feels almost like it's has a leak in the line but there none... I have bleed the brake a few times thinkin it's was bubbles in the lines. I remember the stock s13 when i barely tap the brakes it grabs... with the conversion it's seem to not have enough pressure.... so i just wondering if i have to upgrade the brake booster?
btw, my setup are jdm s14 5lugs...
thanks guys and gals.....
Old 07-23-2009, 09:10 AM   #9
gunmetalr32's Avatar
mine was the same way... until i put a ttz32 brake booster and bmc... 100 times better...
what am i supposed to put here?
gunmetalr32 is offline   Reply With Quote
Old 07-23-2009, 09:54 AM   #10
kool
guess i'll just up the booster.... thx
btw.. is the booster a str8 bolt on?
Old 07-23-2009, 10:29 AM   #11
projectRDM's Avatar
Please quit spewing bullshit. Very few people ever upgrade the booster, it's not required. The master cylinder, yes, but only if going to larger brakes. The OP hasn't said a word about upgrading the brakes at all.
To the OP, I'm betting the calipers are on the wrong side, allowing air to be trapped in them.
Research. Plenty of info on this.
FORMERLY R240NA
Old 07-23-2009, 11:41 AM   #12
Sileighty_85's Avatar
^^ Russ has spoken lol
x2 on the bleeders upside down, (they need to on the top)
I never touched my Brake booster
I have S14 Hubs, Full Z32 Brakes F&R, Z31 Brake Master Cylinder (Stock S13 Auto Booster)
Brakes awsome
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 08-13-2009, 11:30 AM   #13
What ebrake cables did you use Sileighty 85?
RichK14 is offline   Reply With Quote
Old 08-13-2009, 11:33 AM   #14
Z32 2+2 cables for S13
S14 is R33 Skylines
The Nismo Shop : West Covina Nissan : Nissan OEM E-brake cables - Z32/R32 conversion
後輪駆動車1番
SEO by vBSEO 3.3.0
