Old 07-02-2009, 02:38 AM   #1
repda916's Avatar
keep blowing tail light fuses
after playing in the mountains and braking hard at a corner my tail light fuse blew. i replaced it and ever since then it blows out within 2min of driving.
lights are not blown. Any help as to what it could be?
repda916 is offline   Reply With Quote
Old 07-02-2009, 02:41 AM   #2
karl wasabi's Avatar
Trader Rating: (29)
Chances are you inner fender harness got cut from your tires. Check that.
karl wasabi is offline   Reply With Quote
Old 07-02-2009, 04:45 AM   #3
repda916's Avatar
wouldnt that cause other problems?
Old 07-02-2009, 08:46 AM   #4
Banned from the Marketplace
Trader Rating: (-1)
Check the fuse make sure its the right amp, check ur wiring behind ur brake pedal u may have a cut wire thats causing a short um lets c, did u ever change the bulb and maybe got the wrong one??
angelom88 is offline   Reply With Quote
Old 07-02-2009, 02:52 PM   #5
repda916's Avatar
will do that, never changed the bulb. b.c they are still good.
i have put every amp fuse in there and they still blow.
Old 07-03-2009, 01:26 AM   #6
YES
if you haven't relocated you wirining harness and its lowered, you need to.
gilby7887 is offline   Reply With Quote
Old 07-05-2009, 11:23 PM   #7
repda916's Avatar
Originally Posted by gilby7887 View Post
YES
i checked the passanger side and nothing is touched.
checked radio ground wire...all good.
Only thing i can think of is lisence plate light touching something?
Old 07-06-2009, 01:01 PM   #8
mine was a short in the passenger front wheel well from tire rubbage as stated above ^^^^^^^
wannaboost? is offline   Reply With Quote
Old 07-07-2009, 12:39 AM   #9
repda916's Avatar
the harness is wrapped in the plastic. hasnet touched the tire at all.
check the radio and made sure no loose wires.
re did the ground.
im fucking clueless.
the cluster and tail lights will stay on as long as i dont drive. as soon as i start the car and start driving the fuse blows
Old 07-16-2009, 03:37 PM   #10
smokestr240's Avatar
are there any cut wires in your stereo harness that arent taped up or caped off? thats wat my problem was
smokestr240 is offline   Reply With Quote
Old 07-16-2009, 05:31 PM   #11
gotspins13's Avatar
Send a message via Yahoo to gotspins13
dude its your piggy lip thats blowing them!, just give that shit to meeeeeeeee
perfectly said!
FJ20ET 16 valve - the holy grail of Nissan engines
gotspins13 is offline   Reply With Quote
Old 07-16-2009, 05:38 PM   #12
Send a message via AIM to SHIFT_destroy
hmm im having a similar problem and ive checked everything my running lights wont work along with my cluster lights and my brake light fuse blows anytime i touch the pedal i dont have the slightest clue why and it just started doing that one day out of nowhere
SHIFT_destroy is offline   Reply With Quote
Old 07-17-2009, 11:02 AM   #13
projectRDM's Avatar
For the sake of your car, don't do that. Fuses are rated to a specific amperage for a reason. Putting larger fuses in will just burn up the wiring harness instead.
FORMERLY R240NA
Old 08-21-2009, 12:00 AM   #14
same problem
same problem i no..
gots13? is offline   Reply With Quote
Old 08-21-2009, 12:10 AM   #15
Bad ground, had that problem found out one of my grounds came loose under the carpet by the seat.
WTB s13 side skirts.
singlecamslam is offline   Reply With Quote
SEO by vBSEO 3.3.0
