| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Premium Member ![]() | S13 Power window woes. Okay, did a search and couldn't find a thing so I am going to post. Last year my drivers side window failed to go back down after I put it up. I hit the switch, and I get a click at the amp, but the window doesn't go down. I checked a known working window motor, and that didn't work either, amp still clicks and no go. I don't think it's the switch because the amp is kicking on. Any other ideas besides the amp or switch? Oh, it's a 90 hatch. |
| Sponsored Links | |
| | #2 |
| Post Whore! ![]() | Check for power at the motor on both sides, up and down. If yes, the motor is bad. If no, the amp or switch is bad. To determine which, check for ground signal from the switch to the amp on both sides as well. The FSM has a schematic, it's a very simple system.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
