| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Leaky Injector | Nissan 240sx S13 Brake System: power break unit, break pedal height and more Click on the link to see the complete article with images check it out here: Nissan 240sx Brake System (s13). Garage411.com 240SX brake system is operated hydraulically using a tandem master cylinder and vacuum power unit. All models have front and rear disc brakes. BRAKE BLEEDING PROCEDURES Check fluid level in master cylinder frequently during bleeding procedure. Bleed brake system in proper sequence.
ADJUSTMENTS POWER BRAKE UNIT OUTPUT ROD 1. Attach a hand-held vacuum pump to power brake unit supply port. Apply 20 in. Hg vacuum to power brake unit. Measure length of output rod extending from power brake unit housing. 2. Adjust output rod length if necessary. If output rod length cannot be adjusted properly, replace power brake unit. BRAKE PEDAL HEIGHT AND FREE PLAY 1. Measure pedal height from pressure face of pedal pad to floor pan insulator, without carpet.
PARKING BRAKE 1. Remove parking brake lever cover. Raise and support rear of vehicle. Pull up on parking brake lever using force of 44 lbs. (20 kg). Rear wheels should lock at appropriate lever stroke.
STOPLIGHT SWITCH AND AUTOMATIC SPEED CONTROL DEVICE SWITCH 1. Both switches are located below dash panel, at brake pedal bracket. Adjust brake pedal height.
Click on the link to see the complete article with images check it out here: Nissan 240sx Brake System (s13). Garage411.com |
| Sponsored Links | |
| Bookmarks |
| Tags |
| 240sx brake system, 240sx brakes, garage411.com, s13 brake system, s13 brakes |
| Thread Tools | |
| Display Modes | |
