Old 06-29-2009, 09:50 PM   #1
Nissan 240sx S13 Brake Pad Removal and Installation
Click on the link to see the complete article with images check it out here:Nissan 240sx Brake Pad Removal and Installation. Garage411.com
WARNING:
Take care not to breath in brake dust. Brake dust is filled with asbestos which causes mesothelioma cancer and or tumor. Mesothelioma destroys tissue and organs and have the potential to spread to other parts of the body. Always clean brake parts with a certified brake parts cleaner before working on the brake system. This will reduce the amount of exposure to asbestos.
FRONT BRAKE PADS
Removal
1. Raise and support front of vehicle. Remove wheel assembly. Remove bottom guide pin. Rotate caliper body upward on guide pin.
2. Remove pad retainers, shims and brake pads. Note pad condition and location for proper installation (if reusable). Minimum pad thickness is .08" (2.0 mm) for all models.
Installation
1. Clean piston and area around lock and guide pins. Install inner pad. Seat piston by placing lever through opening in caliper body and pushing piston into bore. Apply brake grease to pad retainer points on caliper assembly. Install outer pad and shims.
2. Install pad retainers. Rotate caliper body down into original position. Install lower lock pin. Tighten bolts to specification, and depress brake pedal several times to seat pads.
REAR BRAKE PADS
Removal
1. Raise and support rear of vehicle. Remove rear wheel assembly. Release parking brake. Remove parking brake cable retainer (if equipped). Remove lower pin bolts, lock spring and pad retainer spring (if equipped).
2. Rotate caliper upward. Remove pads and pad shims. Note locations and condition of pads for proper installation (if reusable). Minimum pad thickness is .08" (2.0 mm).
Installation
1. To install, reverse removal procedure. Clean area around pin bolts and piston end. DO NOT damage piston boot. Retract piston into cylinder body by turning it clockwise.
2. Apply silicone brake grease to caliper sliding surfaces and pad contact area on mounting support.
spartanic is offline   Reply With Quote
garage411.com, s13 brake pads, s40sx brake pads
SEO by vBSEO 3.3.0
