Old 06-17-2009, 11:04 PM   #1
help plz. kouki tail light install
I have been searching for quite a while but 59 pages is a lot. Can some one please help me on how to wire the 180sx kouki tail lights, or if you have a site with instructions.
sp3ckz is offline   Reply With Quote
Old 06-17-2009, 11:26 PM   #2
mazersx's Avatar
Trader Rating: (18)
Send a message via AIM to mazersx
aren't they plug and play?
mazersx is offline   Reply With Quote
Old 06-17-2009, 11:27 PM   #3
JVD
No.
Should be really simple to figure out. Look at old harnesses... see where wires go. Look at new kouki harnesses.
Splice accordingly.
JVD is offline   Reply With Quote
Old 06-17-2009, 11:31 PM   #4
okay i went and looked at the wires, do they match up like this??
INDICATOR
Black---Black
Green---Green/Yellow
BRAKES
Black-----Black
Green/Wh---Red/Blue
Green/Yel-----Red/Green
REVERSE
Same
Old 06-18-2009, 02:55 AM   #5
JVD
I don't know. Just look at where they go to on the actual bulbs. Then cross reference.
Old 06-18-2009, 03:05 AM   #6
Just got done with the instal and it worked! Yup if anyone needs to know just follow my outline for the wires! :]
INDICATOR
Black---Black
BRAKES
Black-----Black
Green/Wh---Red/Blue
REVERSE
Same
Old 06-18-2009, 04:38 PM   #7
murderrsirenss's Avatar
Send a message via AIM to murderrsirenss
^did that with mine, but only 1 reverse works, both have fresh bulbs.
murderrsirenss is offline   Reply With Quote
Old 06-18-2009, 08:18 PM   #8
projectRDM's Avatar
The plugs match up exactly the same, they're just a different size, just go from pin to pin from old plug to new. Takes less than 5 minutes.
FORMERLY R240NA
Old 06-18-2009, 09:19 PM   #9
4x4le's Avatar
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
Find out what the problem is, does the ground wire on the non working bulb see ground? Does the power wire not get power when the light should be on? If the groundwire dont see ground then ground it. If it does not get power steal the power from the working side.
NEW/CHEAP s13/14sr CAS
Authorized NIStune Dealer
4x4le is offline   Reply With Quote
Old 06-18-2009, 09:32 PM   #10
hOngsterr's Avatar
interesting
89 FB DD/DELAYED PROJECT.
kouki, kouki 180sx light s13
SEO by vBSEO 3.3.0
