Old 06-06-2009, 03:31 AM   #1
Shadowhunter's Avatar
s14 S14 subframe question
I am in the process of putting my subframe back into the car. When I went to look at the hardware to connect the subframe back up I can only find two cups and two nuts. Since I removed it about 6 months ago I cannot remember if I am missing the other two cups and nuts. Chiltons shows there are 4 but the FSM shows only two and the subframe brackets in the front holding the subframe on. Am i missing 2 subframe cups or are there only two? Thanks very much in advance.
Edit: To Clairfy here is a picture of what I am talking about. The Rear has cup washers where as in this picture it does not appear that the front does.
Shadowhunter is offline   Reply With Quote
Old 06-06-2009, 07:19 AM   #2
HYPNOTIK's Avatar
There are 4.
HYPNOTIK is offline   Reply With Quote
Old 06-06-2009, 10:01 AM   #3
projectRDM's Avatar
There are not four, the front ones are brackets, no cups. The cups are only used in the rear.
FORMERLY R240NA
projectRDM is online now   Reply With Quote
Old 06-09-2009, 12:56 PM   #4
2 cups 4 nuts and 2 14mm bolts for the brackets
dfitzg is offline   Reply With Quote
Old 06-09-2009, 02:54 PM   #5
HYPNOTIK's Avatar
Shit, my bad. I have to go outside and look now.
Old 06-09-2009, 03:38 PM   #6
Bigsyke's Avatar
4 14mm bolts.
Go solid and ditch the cups
Bigsyke is offline   Reply With Quote
Old 06-10-2009, 06:35 PM   #7
Originally Posted by Bigsyke View Post
4 14mm bolts.
What would the advantage of doing something like that be?
Old 07-02-2009, 09:03 PM   #8
Send a message via AIM to jivetoast
you would have a more soild feel to it, depending how you drive it (ie: daily driven/weekender) depends on weather to go soild or not, i recently took my soild bushings out cause i felt every rock on the damn road. your choice.
jivetoast is offline   Reply With Quote
SEO by vBSEO 3.3.0
