Old 05-20-2009, 02:08 AM   #1
Send a message via AIM to kafanylovesme
Brake help ASAP
Hey zilvia, figured I'd ask you guys since I've searched and can't really find anything else.
So, problem is that my brake pedal on my S13 is soft up until the 3rd or 4th time i pump it. It used to go all the way down so obviously it has gotten better. I've bled the brakes for hours, but the problem doesn't seem to go away. It got a little better yesterday where it would get hard by the 2nd pump, but went bad again by today.
I installed a new BMC, don't have ANY leaks anywhere, brake booster is good and I've bled for hours. I'm really not sure what could be the problem or what to check anymore so if you can help, please chime in.
kafanylovesme is offline   Reply With Quote
Old 05-20-2009, 02:29 AM   #2
DreamN's Avatar
Trader Rating: (29)
Send a message via AIM to DreamN Send a message via Yahoo to DreamN
Did you get the calipers off Al?
Old 05-20-2009, 02:55 AM   #3
Yup and still the same old thing. It got a little better with his calipers, but still not where I would like my brakes to be.
Old 05-20-2009, 02:58 AM   #4
HYPNOTIK's Avatar
You either got a leak or it needs bled. There's not a whole lot to the brake system, it's pretty simple.
Do you have ABS?
HYPNOTIK is offline   Reply With Quote
Old 05-20-2009, 03:03 AM   #5
You think I should just keep on bleeding it Hypnotik? That's what's frustrating me that there isn't much to this problem but yet it still exists.
And no, my car does not have ABS.
Old 05-20-2009, 03:09 AM   #6
Felipe's Avatar
i think my car did that at one point... car stoped good, but was soft the few pumps. i did every thing right. in a couple a days (a week i think) it went back to normal.
NO MORE S13, but im still on here
Felipe is offline   Reply With Quote
Old 05-20-2009, 03:12 AM   #7
Lol it went back to normal like nothing?
Old 05-20-2009, 03:15 AM   #8
I10cruiser's Avatar
Trader Rating: (47)
Send a message via AIM to I10cruiser Send a message via Yahoo to I10cruiser
is the fluid clear/clean?...maybe a clog of some sort?
I10cruiser is offline   Reply With Quote
Old 05-20-2009, 03:20 AM   #9
Hmmm thinking about that. Most of the times I bleed, I get fluid a little darker than it is out the bottle. How can I tell if there is a clog?
Old 05-20-2009, 03:27 AM   #10
MrChow's Avatar
Send a message via AIM to MrChow
Not to be mean but how did you bleed it? Are you doing it with someone else or do you have a speed bleeder?
I when through a lot of brake fluid before my stuff was all clean. IMO keep bleeding.
Also you said you installed a new MBC. Did you clean off all of the lines when you put the new one back on?
Looking for S14 Radio trim
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
MrChow is offline   Reply With Quote
Old 05-20-2009, 03:28 AM   #11
I10cruiser's Avatar
Trader Rating: (47)
vacuum pump i guess. . .i just used a vacuum pump thing to do my brakes and its 10 times better then when i bleed it normally with another person. ..i dont know how to check for clogs though
Old 05-20-2009, 03:36 AM   #12
Yes, I bled them with someone else. And yup I cleaned all the lines and bench bled the BMC as well. I think I'll keep bleeding like you said until all the fluid is clean and clear. I'm trying to look for a place around me where I can go pick up those speed bleeders but no luck so far.
Hmm alright I'll look into getting a vacuum pump.
Thanks for all the help so far guys.
Old 05-20-2009, 03:39 AM   #13
Felipe's Avatar
yeah it was from god or some thing... i was about to start busting out with the tech bull. when it just went back to normal. never had a prob. again after that. call me lucky i guess.
Old 05-20-2009, 11:39 AM   #14
MrChow's Avatar
I when change out all of my lines for new SS. I had to bleed it my brakes with a HUGE air bubble in my lines now that was gay.
I when through a whole bottle and a half to bleed all 4 of my lines till they were clean and had no air in them. Order speed bleeders or get a vacuum pump. It'll make your life easier.
Old 05-20-2009, 12:26 PM   #15
DreamN's Avatar
Trader Rating: (29)
Peter, take your bleeder screw to autozone and see if it matches any of the ones they have. Try Empire Hardware (Devonshire and Sepulveda Next to Bank of a America) You could also just buy them off of Kuah (SPL Parts). Dude ships pretty fast to CA.
I'll ask around for local spots that might carry them for sure.
Old 05-20-2009, 12:36 PM   #16
nightsauce's Avatar
Send a message via AIM to nightsauce
this happened to me before when i was doing the z32 brake upgrade. The stock brake MC blew out when I put the new brakes in. I put in my new brake MC and it worked fine.
nightsauce is offline   Reply With Quote
Old 05-21-2009, 01:25 AM   #17
That first part was a little tough to read lol, but I got it. Yeah I went and bought a vacuum pump today. Went at the brakes for about an hour. Going back and forth to each caliper. Still not much of a difference =/. It's perfect and how it should be when the car is off, but when I turn it on and pump the brake, it grabs up until about the 2nd pump. Also, the fluid is coming out clean now as well.
Sorry for being a noob lol, but how am I sure when the air is out using the vacuum pump? Is it as simple as me not seeing the bubbles anymore?
Thanks Jimmy, I'll definitely look into that.
Do you guys think that if I drove the car around a bit the brakes would get a little better like what was said above?
Thanks for all the help guys!
Old 05-21-2009, 01:29 AM   #18
Send a message via AIM to rancid240
Maybe check the vacuum hose to the brake booster?
rancid240 is offline   Reply With Quote
Old 05-21-2009, 01:36 AM   #19
Already checked all hoses and lines rancid.
SEO by vBSEO 3.3.0
