Old 05-05-2009, 10:54 PM   #1
Sideways_blksr20's Avatar
Send a message via MSN to Sideways_blksr20
Unhappy S13 pulls hard to da right after track
I went to da track last week and while I was sideways my tire blow up . After dat my car keeps pulli g to da right , I took it to get an algment and still pulls nothing change
I nstall aftermarket toe rods and rucas and still the same
Idk what else to look nothing underneath looks bend it
I noticed that when I floor it and let go of the gas the car moves from side to side
If it helps
M egan track coilvers brand new
Aftermarket tie rods
Afemarket toe rods
Aftermarket rucas
Front and rear upper strut bars
Welded
Everythng started to happn after I blew a tire on da track I only drove with da half of da tire off for like about 50ft
Any suggestions would be aprreciat it
Thanks
Sideways_blksr20 is offline   Reply With Quote
Old 05-06-2009, 12:36 AM   #2
5t341tH's Avatar
Send a message via AIM to 5t341tH
sometimes, tires can cause pull. its called radial pull. try swapping the wheels across. (switch em) and see if it goes away.
lexus baby
5t341tH is offline   Reply With Quote
Old 05-06-2009, 06:25 AM   #3
I did and still da same
Old 05-06-2009, 06:26 AM   #4
I can only swap the ones in da front cause my rear tires are wider dan the front ones
Old 05-06-2009, 11:15 AM   #5
5t341tH's Avatar
well it seems that something might be bent/broke in ur suspension. take a close look. that is the only available reason
lexus baby
Old 05-06-2009, 11:40 AM   #6
Deadpool is NOT dead!
FaLKoN240's Avatar
Check for bent linkages, if you don't tell us what kind of "aftermarket" arms they are, and you mention Megan, you probably don't know and they're some shitty ebay brand. I'd start there.
Originally Posted by Brian View Post
you DUMMY.
you painted the insides black?
WHY STEWBERT
Good lulz there.
Old 05-06-2009, 11:41 AM   #7
Send a message via AIM to TravisSW
How hard is it to type "THE" or "THAT?"
I know it's the intraweborz, but jees, make yourself sound like an idiot.
280k High Mile Club! 7/1/08
Cyl 1: 155 C2: 120 C3: 150 C4: 145
TravisSW is offline   Reply With Quote
Old 05-06-2009, 12:10 PM   #8
FaLKoN240's Avatar
Come on man, everyone knows that D and A are like right next to each other, he can type THE OR THAT with just his LEFT had by using da.
you DUMMY.
WHY STEWBERT
Good lulz there.
Old 05-06-2009, 04:36 PM   #9
Fonzs13's Avatar
s13
did your tire blow up on the rear or the front of the car?
Fonzs13 is offline   Reply With Quote
Old 05-06-2009, 10:08 PM   #10
On DA rear
Old 05-22-2009, 04:52 PM   #11
Fonzs13's Avatar
you might want to check your rear spindle sometimes when they go bad the car pulls one direction....
Old 05-22-2009, 05:01 PM   #12
brokeAs240sx's Avatar
Send a message via AIM to brokeAs240sx
to da left, to da left, everything you own in a box to da left... of ur car, then the weight will balance & ur car will go straight.
on a more serious note:
- drifting, blow tire, skid 50 ft w/ no tire = you blow'd something up more than just the tire.
- check your arms & shocks & pretty much everything connected to the suspension again.
- did you check the condition of your tires or tried rotating them?
- tried putting on different wheels (your rim w/ the tire blow out could be out of round now, causing weird stuff to happen)
Obviously, when stuff gets screwed up, the best course of action is to leaving anything that could have been damaged out of the equation.
You said you did an alignment - no help, then aftermarket ruca's, etc - no help
Did you get an alignment again after changing out the whatever suspension components you did after?
For the alignment, did the shop do a 4 wheel alignment & give you a printout w/ the thrust angle? scan/take a picture/post results of the alignment.
Maybe even take pictures of your suspension components (each corner of the car & from different angles) - maybe someone will be able to spot something you missed.
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 05-22-2009, 05:35 PM   #13
Could be a flat spot on of DAAAA tires, but you'd get a shimmy WIT DAT
Ball Joints
Tie Rods
DA DA DA DA DA DA
DA?
g'damn that's annoying.
PHeller is offline   Reply With Quote
Old 05-22-2009, 05:37 PM   #14
Originally Posted by PHeller View Post
g'damn dat's annoying.
there, fixed it for you
bew bews!
Old 05-26-2009, 01:16 AM   #15
2toneluv's Avatar
dan? da? dat? come on now
2toneluv is offline   Reply With Quote
Old 05-26-2009, 01:19 AM   #16
Somnambulist's Avatar
Send a message via AIM to Somnambulist
Don't confuse the man with your proper spelling and grammar and technical talk....
S13 status: Engine replacement underway...
Somnambulist is offline   Reply With Quote
SEO by vBSEO 3.3.0
