| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia.net GB Vendor ![]() | Hyrbo E-Brake install on s13 (help)? hey all Since my car is a track car i want to convert from z32 ebrake set up and install a ksport one or a better one. i did a search and no one had a install thread on one..Has anyone put one of these in at all on a s13? I am wondering even if i buy there install kit where to i tee in lines and which ones...Also if any one has done their own hydro e-brake im sure its all the same type of install. If so any help would be great... Jim Last edited by JTunedMotorsports; 05-03-2009 at 04:02 PM. |
| Sponsored Links | |
| | #5 |
| Zilvia.net GB Vendor ![]() | pdm? I meant k-sport low end....heard and got feedback from ppl using their parts...then u got the average joe that comes in my shop and loves the k-sports b/c they got them cheap lol.. wow i guess im going custom e-brake or part show max...ppl post up ure ebrake set ups. |
| | #6 |
| Zilvia Member ![]() | yeah i was stoked on my ksport products when i dished out the cash.... then after using other higher end parts i will never go back to the "cheap alternitive" Once i swap my rear brakes for the z32 rears i will switch to the PSM Hydro E brake kit then ad a "park lock" in line for a usefull e brake since i still daily my ride.... |
| | #7 |
| Zilvia Member ![]() | MAX Hydro Brake Version 2.0 In stock in the USA NOW! Standard Hydraulic side brake version two features include: ~More brake line pressure ~Willwood master cylinder ~Adjustable bump stop ~Steel tranny housing reinforcement plate ~Extra long handle ~Heim joint linkage ~Delrin Bushings ~Bomb proof steel case ~Foam rubber grip $220 + Shipping + $80 for Earl's Stainless steel lines and fittings Tension Rod Handle option is $100 extra. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() To order from MAX USA call 858-566-6969 or email your shipping address for a complete quote including parts and shipping to -email- heres the install pix, simple huh! The top port on the hand brake goes to the OEM master cylinder's rear brake output, the end port of handbrake goes to the hard line that used to screw into the OEM master. Tack weld a reinforcement plate of 1/8" steel to the tranny tunnel, and weld or bolt the hydro brake box to that. This method is really strong so it does not wiggle and flex like other brakes. ![]() ![]() ![]() ![]() |
| | #8 |
| Zilvia Junkie ![]() | Wow, I wasnt considering a k sport kit but rather was going to make my own kit using a line lock and making my own lines and all. It was going to be a little cheaper than this but I think Im really going to go with the kit just posted! It looks so complete! And to the op and anyone else, you should not replace or remove your standard ebrake. It would take the cable to snap while parked for you to loose your parking brake which is unlikely, however pressure loss over time in the brake line is a possibility and your car will roll wherever gravity will take it. The hydro brake is used for drifting, not parking. |
| | #10 | |
| Zilvia Junkie ![]() | Quote:
Drifting yes parking no! | |
| | #11 | |
| | #12 |
| Zilvia.net GB Vendor ![]() | sure...just listen il use the brake only...but our customers and shop cars dont run that stuff..btw everyone i got the k sport brake coming in so il keep ppl posted on the install and if it holds up.. |
| | #14 |
| Zilvia.net GB Vendor ![]() | yes if ure loosing ure ebrake it bc of ure bbk which z32 prob wont work on rotora..id just go k sport...im gonna do a write up and try to fiture out my options...i just dont like how there install kit with 2 feet lines wants to u tap into the single hardline for the grear brakes..i want to run my own ss brake lines and tee it for the block on the passenger side front and for the rear just tee of the rear block. all i want o know is what can make custom like 5 foot lines and figure out what fititngs i need |
| | #15 |
| kousoku ![]() | Yeah def post up some pics as we'll probably be figure things out for the brakes in the next month or so. |
| Sponsored Links | |
| | #18 |
| Zilvia Junkie ![]() | The ksport ebrake works well for me. I would have gotten the pbm one but I had this laying around so i decided to use it. I relocated the stock ebrake to the passenger side and welded the ksport unit to the chassis. then you run the lines to the rear distribution block then bada-bing!!! Hydro ebrake > all others ![]()
__________________ http://i89.photobucket.com/albums/k2...logo3small.jpg t-apc.com t-apc.com t-apc.com t-apc.com |
| | #19 |
| kousoku ![]() | that's cool man! That's what my car looks like right now LOL
__________________ 1990 240sx Hatch -- project twoforty 1989 240sx Coupe -- project streetcred motorsports.technoticmedia.com ihatestickers.com |
| | #21 |
| Zilvia Junkie ![]() | nah i plumbed the handle thru the rear brake line block near the passenger side wheel next to the fuel lines. I made custom lines but the ksport ones will work too. It does not connect like the pbm h-brake.
| Bookmarks |
| Tags |
| e-brake, k-sport |
| Thread Tools | |
| Display Modes | |
