| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Leaky Injector ![]() | Weird Clutch, Throwout bearing problem HELP! So I bought an exedy stage 2 clutch kit. Kit # 06953A. I put it in my 97' s14, since then the clutch fork has ben loose on the pressure plate. Like When everythings bolted up, I can move the fork back and forth a little. I didn't think much of it untill I went through 2 slave cylinders, they were over extending and blowing up on me . It seems like my slave is extending way too far to engage the clutch. Its basically fully engaged after I bleed the clutch, is this normal?. I did get the flywheel resurfaced, Is there such thing and grinding it too low? |
| Sponsored Links | |
| | #2 |
| it is possible to install the throwout bearing backwards-that would require the slave to have to move farther- but it would not last long at all and you would be able to hear it. race clutches will shorten the engagment travel somewhat. "Its basically fully engaged after I bleed the clutch, is this normal?" dont understand this. | |
| Bookmarks |
| Tags |
| clutch, problem, throw out bearing, transmission |
| Thread Tools | |
| Display Modes | |
