Old 10-04-2008, 07:12 PM   #1
*BOB*'s Avatar
PS Problems
Hey guys, I just got done searching for an answer but it looks like im gonna have to pick your brains.
For some reason my car is pushing PS Fluid out of the reservoir and I cant figure out why...
fairly new rack (I can tell its been rebuilt)
Just did a flush on it
Had the pressure hose redone just to make sure that wasnt the problem
pulled the reservoir out and cleaned it to make sure it wasnt plugged.
The only thing i can think of is maybe the pump is no good and somehow the pressure is pushing back up to the reservoir.
So my noob questions for you guys are..
Is there a common problem with these?
And if i do have to get a new pump can I get one off of another model or do I have to order one for the SR20?
*BOB* is offline   Reply With Quote
Old 10-04-2008, 07:39 PM   #2
projectRDM's Avatar
How much fluid? If it's just overfilled it will drain out until it's level, but if it's doing more than that then there's a problem. Are you using ATF, or regular PS fluid? PS fluid will breakdown and clog lines, as well as score the bearings in the pump when it boils.
FORMERLY R240NA
Old 10-04-2008, 09:15 PM   #3
*BOB*'s Avatar
Using PS fluid... but it had ATF in it when i bought it. And I know its not overfilled because it will actually keep pumping the fluid out until it doesnt even register on the dipstick.
Old 10-04-2008, 10:29 PM   #4
projectRDM's Avatar
Drain it and run ATF. PS fluid is NOT to be used. You won't know what's wrong until the system is set up properly.
FORMERLY R240NA
Old 10-05-2008, 12:01 AM   #5
*BOB*'s Avatar
So youre actually supposed to run ATF in it?
Old 10-05-2008, 04:56 AM   #6
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
^Yes. I dunno, maybe I'm just really smart, but it seemed like Russ made that fairly obvious in his last post.
Power steering fluid is the devil in 240's.
-Kyle
Old 10-05-2008, 09:40 AM   #7
projectRDM's Avatar
Read the owners manual. Or the FSM.
Nissan, Toyota, and a few other import manufacturers design their power steering to specifically run on ATF. Anything else is shit.
FORMERLY R240NA
Old 10-05-2008, 05:37 PM   #8
*BOB*'s Avatar
either way, its not gonna fix my problem... it had ATF in it when I bought it. Its still gonna spray it all over the place. But I do appreciate the tip. I will change it back to ATF.
SEO by vBSEO 3.6.0 PL2
