Originally Posted by Sileighty_85 the rear is no biggie you MUST have the kouki Wire harnesses for the lights
Everything bolts up you just have cut the the Kouki Plugs and wire them to the S13's OEM plug.
Just do it a wire at a time, and use a test light if you have to. |
Yep, I know that the lights/garnish plates will all fit up right, and I definitely found out the connectors are different, but as far as the harness goes, I just have the chuki harness on the car and just the plugs for the kouki lights, so is that what you mean by the wire harenesses for the kouki lights?
Also, by Kouki front end I mean, the S13 kouki front end, not switching to a 14. I just wanna hear what others have done as far as wiring the corner and marker lights. I'm pretty sure I can make the right swaps on the brackets from the chuki bumper...
