| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia FREAK! ![]() Join Date: Jul 2008 Location: Compton, CA
Trader Rating: (38) Feedback Score: 38 reviews | Sr20 Backfire I'm getting a backfire from my engine. The only time it happens is when I go over 2K RPM, and let it coast down past 1500RPM, and it's only when I'm moving. So whenever I go passed 2K rpm as SOON as it gets to 1500RPM I get the backfire, it's not loud (full stock exhaust) but it's a problem that I would like to get diagnosed/fixed. |
| Sponsored Links | |
| | #3 |
| Zilvia Member ![]() | its the same thing linked to your BOV. you have excess fuel but your BOV has released some of the air that is supposed to be in the mixture. That fuel passes into the hot exhaust and ignites making the noise. it not really a backfire though. a back fire is ignition in the intake, what is happening to you is normal, its the same thing that causes flames to shoot from built turbo cars. |
| | #5 | |
| Post Whore! ![]() | Quote:
Give yourself a dedicated vacuum hose to the BOV and you wouldn't need to recirc the BOV to get it to stop backfiring. | |
| | #7 |
Trader Rating: (0) Feedback Score: 0 reviews | Interesting! I've had the same issue with the backfire issue on decel around 1500rpms. I've only had the issue since I installed my new Greddy Type-S BOV. With my HKS SSQV I've never really had the backfiring on decel issue. I think I'm going to have to get an SAFC so I don't have to recirculate. I love the type-s sound. LOL! BTW my bov is not tee'd off, it has it's own line coming from the bottom of the throttle body. So I don't really know if it's just the Tee'ing thing that is causing your issue like the last person said. All I know if that I don't want VAC applied to my wastegate, so I tapped into my hotpipe and installed a nipple that runs a vac line from the hotpipe straight to my wastegate. when I had my bov tee'd with my wastegate, I was getting weird boost issues. no problems now. runs like a champ. |
| | #8 | |
The nipple on the bottom of the throttle body is not a source for vacuum. The hole where that nipple draws air from starts right underneath the throttle butterfly, making it a "positive pressure only" nipple. You need to use the nipple on the top right of the intake manifold, right after the throttle body. The one on the left is good for the FPR, and people usually tee that line off to the boost gauge. The one on the bottom of the throttle body you could use for the WG. If you run your vacuum lines like this, and you mess with the GReddy Type-S's spring pressure (and make sure you take the little spring out, I heard that makes it work better), you shouldn't have the backfire at 1500rpm upon decel in gear. | |
| | #9 |
Trader Rating: (0) Feedback Score: 0 reviews | LOL! i'm sorry I was thinking of which one I capped off. Yeah my bov is connected to the top right. fpr is on top left. and i capped off the bottom one. Sorry about the mix up. I just posted on another post about my vacuum setup... but i didn't F it up on my other post. LOL! sorry but ^ is correct. top right is bov. but are you saying i should take the adustment spring out to stop the backfiring? |
| | #10 | |
Some people have said that if you remove the smaller spring inside the Type-S's diaphragm chamber then it would open better, while being able to adjust it so it doesn't open under idle or open at 1500rpm. Do a search on here about it. It's been discussed a few times. | |
| | #11 | |
Trader Rating: (0) Feedback Score: 0 reviews | Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
