Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > S Chassis
Old 08-22-2008, 05:41 PM   #1 (permalink)
bblack_91240's Avatar
Z32 uprights onto an S13
I know that Z32 uprights fit on an S13 when using coilovers that have the special fork style end, but has anyone used a Z32 rear strut instead of going with coilovers. I'm curious to see if they bolt right up. I've heard that they might, but I'm not gonna tear my HICAS subframe out to put the non HICAS subframe and Z32 uprights on if I can't use the struts. Also, if you have any other methods to get the uprights to work that'd be great. THANKS!!
DO
bblack_91240 is offline   Reply With Quote
Old 08-22-2008, 05:43 PM   #2 (permalink)
s13boy89's Avatar
Send a message via AIM to s13boy89
what do you want the uprights for the internal e brake
s13boy89 is offline   Reply With Quote
Old 08-22-2008, 11:05 PM   #3 (permalink)
I needed non HICAS uprights to replace my HICAS uprights and the Z32 uprights work with the non HICAS suspension. So when I replace the rear subframe and use toe arms instead of tie rods I can use these uprights. I'm also doing the rear brake upgrade, but that was just another perk. They are also aluminum, so they're light as shit!
DO
Old 08-24-2008, 10:18 AM   #4 (permalink)
Does anyone have any info for me?!
DO
Old 08-24-2008, 04:05 PM   #5 (permalink)
In house son of a bitch
projectRDM's Avatar
Z32 shock bolts right in. You can still use S13 springs, or go to the stiffer Z32 spring.
FORMERLY R240NA
Old 08-24-2008, 08:48 PM   #6 (permalink)
Thanks bro thats what I needed to know!
DO
SEO by vBSEO 3.2.0
