| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 (permalink) |
| Z32 brake swap to a s14>>>> i did the z32 swap and everything works fine but when i turn a hard turn like say pull a tight u turn you can hear it grinding on the caliper i assume. i have washers spacing the mounting brackets with out them the calipers bind on the rotors...whats the deal? | |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #2 (permalink) |
| Pink GodziRa ![]() | u dont need to add any washers to the calipers. its a straight bolt on you're pads maybe toasted too possibly could be a few things best bet is take off the wheel and inspect the install something might have gotten loosey goosey
__________________ Aaron Pink GodziRa |
| | #3 (permalink) |
| In house son of a bitch ![]() | NA calipers on TT rotors probably.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #5 (permalink) |
| Premium = $2.00 a Gallon ![]() | Did you modify your dust sheilds at all? They might be touching. Mine did something like that only when I turned. I just had to give it some more "love". Last edited by slidingsky; 08-21-2008 at 02:16 PM. Reason: dust not heat |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
