| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 (permalink) |
| spedo el failo my friends car is on like a speedo tripp right its like this vroooomm bummmmmm like it hits limiter but thats not the issue the speedo will go on random hay wires like its retarded it will stay at the speed then fall then come back and fall again and when this happens his method of getting it back is to stab the brakes and it works and even if he stops for a good ten to fifteen mins everything is hooked up and good to go just have no clue why it is doing this any help would be appreciated | |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #2 (permalink) |
| Zilvia.net Advertiser ![]() | Thats just a simple short in the wiring you have. Check wires to the speed sensor as well as wires from the ECU... And learn to use periods man its very difficult to read what you wrote..
__________________ www.massimopower.com Open Mon-Fri 10am-6pm but online all the time lol Special Thanks To: www.jlbmotorsports.com www.wiredonhonda.com For Their Continued Support |
| | #4 (permalink) |
| Zilvia Junkie ![]() Join Date: May 2008 Location: Da L dot A dot; Planet Los Angeles, ...you know!? Age: 37
Trader Rating: (2) | My speedo does the same thing. I baught a speed sensor at Autozone for around $72 yesterday. I'm gonna check the connections first and if that doesn't work I'm gonna put in that speed sensor. I'll let you know if that fixes the speedo.
__________________ |
| | #6 (permalink) | ||
Trader Rating: (2) | Quote:
![]() Quote:
![]() Now I'm gonna try to use a different guage cluster to see if that fixes my spedo problem.
__________________ | ||
| Bookmarks |
| Thread Tools | |
| Display Modes | |
