Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > S Chassis
Old 08-15-2008, 01:21 PM   #1 (permalink)
SkylineJeff's Avatar
Entire rear end swap for S13
Does anyone know which entire rear end setup can be swapped onto an S13, I have available an R32 GTR rear end, a Z32 N/A and a Z32TT rear end, which one can or would be best to swap for a high torque drift car?
SkylineJeff is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-15-2008, 04:43 PM   #2 (permalink)
Gangsta ish.
awesomenick's Avatar
By entire rear end do you mean diff, hubs and axles?
USDM S13 and S14 are R200's with 29-Spline output shafts, 6-Bolt axle cups (3 pairs of 2 bolts in a "Y" shape) most were 4.08:1 ratio.
USDM Z32 NA are R200's with 29-Spline output shafts, 5-bolt axle cups, 4.08:1 ratio.
USDM Z32 TT are R230's with 30-Spline output shafts, 6-bolt axle cups (the 6 bolts are evenly spaced in a star), and 3.69:1 ratio
USDM G50 (Infiniti Q45) are R200's with 30-Spline outpus shafts, 6-bolt axle cups (the 6 bolts are evenly spaced in a star), and 3.54:1 ratio
JDM R32 and R33 are R200's with 30-Spline outpus shafts, 6-bolt axle cups (the 6 bolts are evenly spaced in a star), and 4.08:1 ratio
Copied and pasted. There's a possibility of that being inaccurate.
awesomenick is offline   Reply With Quote
Old 08-15-2008, 06:21 PM   #3 (permalink)
g6civcx's Avatar
Not most. All!
There are also choices from Pathfinders with R200 diffs.
g6civcx is online now   Reply With Quote
SEO by vBSEO 3.2.0
