Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > S Chassis
Old 08-13-2008, 12:35 PM   #1 (permalink)
spartanmisfit's Avatar
Help Tranny/ clutch problem
My clutch won't go into gear unless I push as hard as I possibly can and when I do that the clutch is already partially engaged, so it starts to take off. I've got the sr20 red top conversion. Any ideas? Sorry there's not much info I've gotta get to work.
spartanmisfit is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-14-2008, 05:38 AM   #2 (permalink)
s13boy89's Avatar
Send a message via AIM to s13boy89
adjust the rod thats under the dash connected to the clutch pedal
s13boy89 is offline   Reply With Quote
Old 08-16-2008, 03:18 PM   #3 (permalink)
Massimo Power's Avatar
Send a message via AIM to Massimo Power
adjust the rod and also check the master and slave cylinder for leaks or for proper function... and dont forget to top off the fluids.. if everything looks good .. maybe try bleeding it...
www.massimopower.com
Open Mon-Fri 10am-6pm but online all the time lol
Special Thanks To:
www.jlbmotorsports.com
www.wiredonhonda.com
For Their Continued Support
Massimo Power is offline   Reply With Quote
Old 08-16-2008, 03:36 PM   #4 (permalink)
Love, Peace and Tire Screetch!
Vision Garage's Avatar
Send a message via AIM to Vision Garage
yes rebleed the clutch and check the rod on the master cylinder. Has this always been happening or was everything fine and dandy before?
Vision Garage is offline   Reply With Quote
Old 08-16-2008, 04:21 PM   #5 (permalink)
626DRIFT
ericcastro's Avatar
Also look at your slave cylinder to double check the 2 bolts that hold it on are snug
Looking for ziptied vouch.
SEO by vBSEO 3.2.0
