| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 (permalink) |
| Premium Member | emanage on ka-t? i am putting together a turbo project and at first was going to use the safc neo.. but doing some research, i found out that it isnt a very good way to go. so one of my friends told me to use emanage instead... i was lookin it up and doing some research and it isnt very expensive.. but i was just wondering what all i would need. there is a bunch of harnesses that are sold separately.. a little input? (on harnesses and emanage) and if it helps.. im going to be running around seven pounds.. then after a little while im going to be putting in eagle rods and cp low comp. pistons and raise the boost to atleast 11 psi. thanks ![]() |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #2 (permalink) |
| Premium Member ![]() | i have a emanage ultimate for sale if you are interested with harness. I also have a obd 2 to obd 1 harness as well. So technically with this set up you can hook up the emanage ultimate and then hook up a obd1 ecu. I was going to use this on my ka-t but decided no to go turbo. also ka-t.org will pretty much answer any questions u have regarding turbo in a ka(d)e |
| | #6 (permalink) |
| KA-T > SR ![]() | yeah if your going to run a safc get an rom tune and wideband then fine tune it with the safc... thats what i did and i love it, but there is no replacement for full stand alone |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
