| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #3 (permalink) |
| Premium Member | it has the half that connects to the gauges, the other half is cut.. i guess so the person could wire them in. I just tried to figure it out and there are two wires that have open butt connectors, im guessing one for boost and one for oil pressure. what wire do i connect the oil pressure gauge to? anybody know?.. i just tried to connect it to the oil sending unit wire(yellow with green stripe) but it didnt do anything. |
| | #4 (permalink) |
| Zilvia Junkie ![]() | six wires, two for illumination, one to ignition, one to ground, and one for boost and oil signal. The boost signal will come from the boost sensor mounted. Oil signal will come from a true OE oil sending unit. Oil sensor needs to be from a Z32/R32/R33 OPS. Also you don't need the harness to get it to work, if you look on the back of the gauges you will notice the circuits and each one is labeled. |
| | #5 (permalink) | |
| In house son of a bitch ![]() | Quote:
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com | |
| | #7 (permalink) |
| In house son of a bitch ![]() | No problem.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
