Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > S Chassis
Old 08-09-2008, 09:22 PM   #1 (permalink)
highly responsive's Avatar
Temperature gauge trippin?
I noticed this last night, I went to walmart to get a new key cut, and when I came back to my car, this started happening with the new key. Of course, I was like WTF - so I turned the car off and started her up with the old key - temp and gas gauge went back to normal.
This morning, I started my car and let it warm up, and my gauges were normal (normal being temp @ halfway mark and my gas is EMPTY)
I drive about a mile out and the temp gauge starts creeping up again, same with my gas gauge. So I pulled over to take this picture.
Also, my car isnt actually overheating either. What do I do?? :/
highly responsive is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-10-2008, 04:39 AM   #2 (permalink)
Shut Yo Muthafucking Mouth!!!
fliprayzin240sx's Avatar
Water temp sensor took a crap?
My Penis is so big that if I laid it out on a keyboard, it would go from A to Z!!!
*look down on keyboard*
Old 08-10-2008, 05:45 AM   #3 (permalink)
Chuuko Dori
E Double's Avatar
^ sounds like the problem, try replacing the sensor and see what happens
E Double is offline   Reply With Quote
Old 08-10-2008, 07:16 AM   #4 (permalink)
MODERATOR~Who can't spel gud
S13SilviaGirl's Avatar
Location: I wish I was still in Japan...but I am not :( But on the bright side I am with my family here in the USA and have my cars :)
uhmmmm one of the following:
A) Call in an exorcist
B) Sell the car
C) Burn the car
D) All the above
Just so you know, I kid I kid....
My Review Thread
S13SilviaGirl is offline   Reply With Quote
Old 08-10-2008, 11:37 AM   #5 (permalink)
thanks. is there a writeup on how to install the water temp sensor?
Old 08-10-2008, 11:43 AM   #6 (permalink)
er, forgot to mention im KAE :/
Old 08-10-2008, 12:18 PM   #7 (permalink)
its on top of the upper water neck it simple to replace just look at where it is
selling my baby s14.5 bayside blue sr
Old 08-10-2008, 01:43 PM   #8 (permalink)
g6civcx's Avatar
Before we get into this,
What basis do you have for this conclusion?
Old 08-10-2008, 09:24 PM   #9 (permalink)
been runnin around all weekend, no crazy steam billowing from under my hood. the coolant level in my radiator hasnt dropped at all.
Old 08-10-2008, 09:57 PM   #10 (permalink)
found this pic on google images... could you be a little more specific as to where that might be?
Old 08-11-2008, 04:55 AM   #11 (permalink)
i have a s13 (heads up display) my gauges do the same thing then i tap the gauge cluster a few times and it goes right back try that next time
jdm510 is offline   Reply With Quote
Old 08-11-2008, 09:10 AM   #12 (permalink)
hey man, funny you say that. because now when i turn on my headlights, my cluster goes black. speedo goes black, tach/temp/fuel gauges all go dead. the only things that work are my brake/engine/seat belt/etc lights. so im beginning to think its a prob with my cluster instead.
Old 08-15-2008, 10:17 PM   #13 (permalink)
sbc
sbc's Avatar
Look at where your upper radiator hose connects to the engine.
On the aluminum part (upper neck) there should be 2 sensors.
One will be an actual plug with two (i believe?) wires. This goes to the ECU I think and is not what you are looking for.
Right next to it there is another sensor with just a terminal that the harness connects to similar to what you would find on your starter. Replace this.
My friend had this same problem on his Z32 and I fixed it today with the sensor from my old KA.
sbc is offline   Reply With Quote
Old 08-15-2008, 10:51 PM   #14 (permalink)
g6civcx's Avatar
Not good enough. You need a thermostat to measure water temp.
Otherwise you're just guessing. You may be overheating and not know it.
Old 08-16-2008, 12:15 AM   #15 (permalink)
looks like your check engine light is tripping too? I kid, but anywas bleed the system? maybe some air got in causing your gauge to read off like that. Mine did that and didnt actually over heat and i had a thermostat measure put to the block and head and read fine with the gauge way into the red.
Now i need a SR redtop coilpack cover!!
singlecamslam is offline   Reply With Quote
Old 08-20-2008, 03:42 PM   #16 (permalink)
cluster issue has been fixed.
the solution?
......wait for it
THE BLACK PLUG TO THE HARNESS MYSTERIOUSLY DETACHED ITSELF. PLUGGED THE DAMN THING BACK IN, AND BAM, I CAN NOW OPERATE AT NIGHTTIME.
what a shitty solution, right?
also, fixed my check engine light by getting my cruise control back in effect.
mods, lock this up, thx
posessed s-chassis ftw!
SEO by vBSEO 3.2.0
