| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 (permalink) |
| Leaky Injector | Help! Problem after replaced CAMShafts on SR20DET The engine is a blacktop S13 Sr20DET RWD engine. Long story short. Bought a set of Tomei PonCAMs. Put them in. Engine idled with RPM all over the place. Replaced with Stock CAMs. Engine idled OK stable but misfired every now and then. Took the car for a drive. It cruised OK but misfired every now and then too. When I pushed it, it would just crap out (like hit a wall) around 3000RPM. I opened the Rocker Cover, and went through everything. It seemed that everything lined up pretty good. CAM Senser was installed correctly. Did not seem like skipped a tooth or two with the chain. Any idea what might have gone wrong? Could it be the CAM sensor crapped out during the process, or MAF, Coil, Igniter chip? Thanks for any help! |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #2 (permalink) |
| Shut Yo Muthafucking Mouth!!! ![]() | Could be the CAS since thats the only thing you really fucked around with. Double check your mechanical timing then check your CAS timing...if those dont do it, then check MAF too...
__________________ My Penis is so big that if I laid it out on a keyboard, it would go from A to Z!!! *look down on keyboard* |
| | #3 (permalink) | |
| Leaky Injector | Quote:
Thanks! | |
| | #4 (permalink) |
| Zilvia Addict ![]() | Sounds like you got your canooting valve up against yer flywheel, and well...thats gonna cost ya'. J/K Like flyp said check your mech timing. You could also be 180* out. When checking the marks its best to count the teeth as well as use the chain marks for a guide. Also make certain the cams were torqued down and didnt spin out of time.
__________________ |
| | #5 (permalink) |
| Leaky Injector | Thanks for the help I got here! Problem is now resolved. It turned out to be a cracked spark plug. It seemed that in the process of changing the CAMs, the ceramic neck of one of the spark plug was cracked, which caused misfires, especially under boost. Because, I was changing the CAMs. So, I was misled to think I installed the CAMs wrong. After puting in another set of spark plugs, the car runs good now.BTW, the Tomei CAM did make my car idles a little worse than with Stock CAM. But, I guess that is expected. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
