| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 (permalink) |
| I havn't been able to find a sure answer on this. Does a j30 vlsd affect speedometer? I just picked up a 93 coupe, and it has a j30 vlsd. Does this affect the speedometer? It does also have 18" wheels on it with 245/45 tires on it, so I know that affects it some. Main reason I'm asking is because either my speedo is acting funny (as in reading way faster then I'm actually going, which wouldn't make sense with bigger wheels, they would make it read slower) or this things a lot faster then I expected it to be. At about 6k rpm 4th gear I'm at around 100mph. (on a closed course obviously ) So my question is would the j30 affect my speed and make it read way off, or does that not make any difference?
__________________ 93 Chuki Coupe<95 Zenki-Sold<89 Zenki Coupe-Parted<89 Zenki Hatch-Sold | |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #2 (permalink) |
| Shut Yo Muthafucking Mouth!!! ![]() | Shouldnt make any difference...
__________________ My Penis is so big that if I laid it out on a keyboard, it would go from A to Z!!! *look down on keyboard* |
| | #3 (permalink) | |
| Leaky Injector ![]() | Quote:
As for rim/tire size, there are some calculators online that you can input tire size from the factory and get a resulting tire size for different sized rims. These calculators pretty much allow you to upsize the wheel while maintaining an exact or close to exact overall wheel/tire diameter.
__________________ 1993 AW Mazda RX-7 1997 Nissan Silvia | |
| | #4 (permalink) | |
| Quote:
__________________ 93 Chuki Coupe<95 Zenki-Sold<89 Zenki Coupe-Parted<89 Zenki Hatch-Sold | ||
| | #5 (permalink) |
| In house son of a bitch ![]() | Ratio is the exact same, 4.08:1, unless you got a later model J30t diff, which is 3.92:1. Even that would only be off 1-2MPH. Search would have told you that. The Q45 is the only R200 diff with a lower ratio.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
