| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 (permalink) |
| BANNED | I am having steering wheel vibrations at 65mph+. The bushings have been replaced, wheels are fine, and all the arms are fine (not bent). So, my last idea is changing out the rack and pinion bushings. My questions are; How hard is it of a project and what, if the problem is not resolved, could it be? |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #5 (permalink) |
| Zilvia Member ![]() | shake in the seat is alignment or suspension. shake in the steering wheel is the wheel balance. if there new rims they shouldnt have any dirt or any thing in them to make them out of balance. i would take them back to the shop that "balanced" them and complain because im willing to bet they didnt clean the places they stuck the weights on. those stick on weights fall off real easily unless you use good double sided tape. |
| | #6 (permalink) | |
| BANNED | Quote:
| | #7 (permalink) |
| Zilvia Junkie ![]() | Have you gotten an alignment yet? You can check to see if the steering rack is loose by getting it up in the air with load on the wheels (most likely will need an alignment lift) and turning the wheel to see if there's any play on the rack. Chances are not because of the way the left bushing has a lip on it, the right passenger side does not have this lip and may be able to move, although it shouldn't cause your steering wheel to shake, just some random pullings every now and then. Never hurts to change them out though. Are your tie rods, hubs, and ball joints good? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
