Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > S Chassis
Old 07-30-2008, 07:49 PM   #1 (permalink)
95 engine into a 93 coupe. Questions?
What are the neccessary things to do or connect when putting in a 95 engine into a 93 chassis?
tucsilvia is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 07-30-2008, 08:06 PM   #2 (permalink)
katsu curry demon
aznpoopy's Avatar
short answer: swap intake manifold and use the s13 distributor
long answer: only available upon search
aznpoopy is online now   Reply With Quote
Old 07-30-2008, 08:26 PM   #3 (permalink)
I think exhaust manifold needs to be switched also.
OfourTHREEfive is offline   Reply With Quote
Old 08-09-2008, 08:24 AM   #4 (permalink)
make shure you get correct tranny for the s13. cause the s14 transmission is slightly different. you can stil use if of course but itll have to be slightly modified with the wiring because the connector location and sensors. but its no biggie... im shure you can do it. GL
PANDATECH is offline   Reply With Quote
Old 08-25-2008, 02:47 PM   #5 (permalink)
beat box
fuxsyou13's Avatar
are there any mods you can do to the 95' mani in order for it to work? or is it a must to swap with the old one?
fuxsyou13 is offline   Reply With Quote
SEO by vBSEO 3.2.0
