Old 07-19-2008, 06:38 PM   #1
MrFairlady's Avatar
Send a message via AIM to MrFairlady
Tailshaft seal leak = fragile?? After LSD install
Installed my (1993) J30 VLSD w/ Axles on my SR20'd S13 last weekend.
everything went smoothly of course...Driveshaft is of course the tiniest bit too long (non-abs Shaft) but had no problems installing it.
----NOW-----
I Noticed there is a trans fluid leak at the back of the Trans where the Slip Yoke goes in it seems.
Now,..I'm using my stock KA Driveshaft w/ my SR and I believe we had to remove the Dust Collar.I don't believe The SR Collar works w/ the KA shaft.
This:
Only pic on the net i could find so don't mind...but Is the SR metal and the KA trans Plastic?
Anyway:
Now you would think it would have been leaking before I installed the VLSD but seems I upset something I guess.
Is the Tailshaft seal Fragile?
is that what I need to go ahead and replace ya think?
Anyone else had to replace that seal?
-90 Kouki Hatch
-95 S14 daily project
MrFairlady is offline   Reply With Quote
Old 07-19-2008, 07:08 PM   #2
Sileighty_85's Avatar
The pic is just a dust cover
You dont need the cover if running the KA D/S
there is a small seal behind it
Im sure it needs replacement after 15 years
so just replace it
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Sileighty_85 is online now   Reply With Quote
Old 07-19-2008, 08:18 PM   #3
aznpoopy's Avatar
that seal is super prone to leaking
go ahead and replace it but don't be surprised if you find it leaking again in the future
aznpoopy is offline   Reply With Quote
Old 07-19-2008, 08:29 PM   #4
AFC #1
S14DB's Avatar
There are two steps to the output. The inner has the seal in it and the outter has the dust sheild. Removing the dust sheild will not affect the seal.
What does happen is the seal wears on the DS yoke and gets matched to the DS. When you put your KA DS in it they didn't fit perfectly or it got nicked on the reinstall.
Just replace it any time to remove the DS. It's cheap insurance.
Comments should be taken as Opinions not as Statements of Fact.
Old 07-19-2008, 08:37 PM   #5
MrFairlady's Avatar
hmmm...weird.I guess it was just coencidence (spell) that it wasn't leaking before the install and the driveshaft never came out...to Now its leaking.
Wel I'll order 2 then just to be safe I guess.
Thanks.That answers it.Heavy throttle looks to have them unless anyone has a part #.
-90 Kouki Hatch
Old 07-26-2008, 02:25 PM   #6
dex
dex's Avatar
if you got the part number tell me... mine is leaking too
dex is offline   Reply With Quote
SEO by vBSEO 3.3.0
