Old 07-03-2008, 06:53 PM   #1
Alternative differential gearing
hey i'm wondering if there are oem or aftermarket diffs that will fit an s chassis that have 3.7 gearing or below. or, as an alternative, does any aftermarket company produce ring and pinion sets?
cheapscheisst is offline   Reply With Quote
Old 07-05-2008, 11:05 PM   #2
Somnambulist's Avatar
Send a message via AIM to Somnambulist
What would you need an aftermarket diff for?
Infiniti Q45 also comes with 3.69 gears and should bolt right in. Are we talking S14 or S13?
S13 status: Engine replacement underway...
Somnambulist is offline   Reply With Quote
Old 07-05-2008, 11:36 PM   #3
SoguRacing's Avatar
Send a message via AIM to SoguRacing
stock gears on the s13 diff are 4.083 right? so dropping the gearing to 3.69 would give better highway mileage.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-07-2008, 07:35 AM   #4
i am wondering the same thing
yunk_s14 is offline   Reply With Quote
Old 07-07-2008, 07:43 AM   #5
slidingsky's Avatar
S13 Manual Trans has a 4.08 IIRC the Automatic has a 3.96
S14 Manual Trans had 4.08 as well.
There are plenty of US Nissan Differentials that have lower gearsets. This Mainly includes the 300ZX Q45 & J30 with the 300ZX having the biggest variety.
slidingsky is offline   Reply With Quote
Old 07-07-2008, 08:30 AM   #6
g6civcx's Avatar
As far as OEM goes, Nismo carries 3.7, 4.111, and 4.364. These items are really just OEM parts rebadged as Nismo products with a higher price tags.
If you know what to look for in the parts catalogue, you can find the exact same parts new for cheaper.
The problem I found was that you're really on your own when you start mixing and matching. You either have to spend money at the dealer or at the junkyard, and fitment isn't guaranteed.
Most junkyards wouldn't even let me open the diff to see what I'm getting. There are rumours that a bunch of cars fit, but I want to see for myself.
So if you don't mind digging through the junkyard to find the right ring and pinion with the right bolt size, then go for it. Report back what you find.
I'm personally thinking of doing a Ford 9" swap to get better ratio.
Old 07-07-2008, 08:31 AM   #7
g6civcx's Avatar
Not necessarily true. Usually lowering cruising RPM helps with fuel economy, but it's better to cruise exactly at torque peak because this is the point where your engine is the most efficient, i.e. the engine can use less fuel to make more torque for cruising.
Old 07-07-2008, 06:04 PM   #8
it's an s14, and yeah i've heard about the q45, but wanted to make sure it would fit correctly. also, could i transfer my kaaz 2way from my stock diff to the q45? as people mentioned above, i'm doing this for better gas mileage and better top end once i get a larger turbo.
Old 07-07-2008, 08:36 PM   #9
xkamikazestormx's Avatar
Send a message via AIM to xkamikazestormx
btw the j30s are 3.9 not 3.6
xkamikazestormx is offline   Reply With Quote
Old 07-08-2008, 07:48 AM   #10
thanks for the help
Old 07-08-2008, 11:03 AM   #11
HoW To Swap Q45 Into S13/S14 :
http://forums2.freshalloy.com/showthread.php?t=172393
Hope This Help,
Regardas,
Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 07-08-2008, 07:00 PM   #12
Not sure about that.. I guess you might be able to since they're both R200 diffs..
Someone else might know for sure.
Old 07-09-2008, 04:00 PM   #13
i picked up a q45 diff and put s15 internals in there. the gearing was 3.54.
you also dont have to worry about that 12mm and 13mm bolt thing. the q45 uses 13mm bolts just like the s15
952jz240sxr is offline   Reply With Quote
Old 07-09-2008, 04:42 PM   #14
thats weird. if you used the s15s ring and pinion the gearing should be 4.1
Old 07-10-2008, 12:49 PM   #15
i have the s15 torsen in a q45 diff. so i have 3.54 gearing
Old 07-17-2008, 12:19 AM   #16
so you're saying that i should be able to transfer my kaaz directly from my s14 drive gear onto the q45 one?
SEO by vBSEO 3.3.0
