Old 06-27-2008, 05:43 PM   #1
Shimming an R200 or J30 vlsd
By: Hunter Rodziczak
I could not find a comprehensive guide to doing this, So I thought I would make one for the good of the S chassis community.
Benefits: Get clutch type lsd action for a 1/4 of the price.
Well post j30 VLSD installation I found myself quite unsatisfied with the performance. As with Many VLSd's after becoming heated up they simply refuse to work properly and your VLSD becomes a one tire fire and thats no good. So after looking for upgrades I stumbled across a few options. Since I have a J30 vlsd with 5 bolt output shafts I would have to switch back to the standard 240sx R200 differential housing in order to run a clutch type lsd. I sold my old diff and a clutch type lsd wasn't in my budget. Somehow I stumbled across Shimming. Shimming involves adding an extra shim(s) to the original preload shim and causes the vlsd to lock similarly to a clutch type lsd. This preload shim costs $10 from you local Nissan dealer so this is definitely worth the money.
-Add one shim and vlsd will act similarly to a 1.5 way lsd
-Add two shims it will act like a 2 way/welded diff.
Here is a picture of the Shim with part no: ( this fits both j30 and R200 diffs)
Click the image to open in full size.
Here's your standard diff, Start By removing the diff from the car and unbolting the 8 bolts holding the diff cover on.
Once that is completed, separate the cover like so and before you put the new sealant on remember to scrap off all old sealant and I recommend using brakecleen to clean surfaces before applying sealant back on.
This is what you'll see:
Next before anything else knock out the output shafts. This takes quite a bit of effort but don't be scared they will eventually come out. I recommend hitting them from behind with a hammer:
Next you can take off the cap bolts like so:
IMPORTANT: Remember which side the shafts and caps cam from as to not mix them up
And this is what you're left with:
Next, it's time to pry out the differential. Unless you have superhuman strength you have to get it out using a bar that give leverage:
And end result:
Unless you have a very good impact gun the next part is almost impossible. Take these bolts out to separate the ring gear from the diff.
Next take off these two Phillips head screws.
Pry apart:
The Almighty shim:
Now take this and put it over the existing shim:
And now put the diff back together the same way you took it apart.
Impressions: Awesome locking compared to the stock vlsd can't complain.
Mtndrifter14 is offline   Reply With Quote
Old 06-27-2008, 08:16 PM   #2
UNISA JECS's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
Here goes another link also:
http://www.d1nz.com/forum/viewtopic....561d68f2602e75
Old 06-28-2008, 01:23 AM   #3
derek_s13's Avatar
Send a message via AIM to derek_s13
i think this is one of those things that makes perfectly clear forehead-slapping sense once explained to you..
..but for some reason just did not even cross your mind ever before.
shimming a stock diff ACTUALLY works. duh.
so yeah, i feel stupid, but i'm glad you're intelligent. just wanted to say how cool i thought this write-up was.
derek_s13 is offline   Reply With Quote
Old 06-30-2008, 12:44 AM   #4
Thanks man,
archive fact worthy?
Old 07-10-2008, 12:54 AM   #5
Banned from the Marketplace
motegineon's Avatar
Send a message via AIM to motegineon Send a message via MSN to motegineon Send a message via Skype™ to motegineon
sweetness, now do you have to measure/do the backlash?
if so anyone got a link lol
motegineon is offline   Reply With Quote
Old 07-10-2008, 11:16 AM   #6
awesomenick's Avatar
Trader Rating: (32)
Feedback Score: 32 reviews
I was under the impression that our gear lash was set with washers? Do you have to change their configuration?
awesomenick is offline   Reply With Quote
Old 08-28-2008, 09:02 AM   #7
nope no changes need to be made
Old 08-28-2008, 09:20 AM   #8
SR/RB Guru
Sileighty_85's Avatar
This works good, I had two friends do this 3 weeks ago
後輪駆動車1番
1991 Built SR GT2871R -363whp
1986 SR86 - 200ish http://zilvia.net/f/off-topic-chat/4...ject-sr86.html
Old 08-28-2008, 03:07 PM   #9
Def
Aren't you just causing the gear engagement between the spider gears in the diff to be more heel/root heavy and therefore bind up?
I don't see how this is an "awesome mod." You're just incorrectly adjusting spider gears. Once you get a gear incorrectly adjusted like that, there will be relatively movement between gears as they mesh, which will wear them down in short order. Wear in a diff means metal shavings, which will cause accelerated wear in other components and potentially massive failure.
Old 08-28-2008, 06:21 PM   #10
motegineon's Avatar
well in that case dont drift or drive your car hard because your wearing it faster, inevitably causing your vehicle to fail..
btw im one of the people that shimmed my diff about a month ago and it is still fully locked and feels amazing
Old 09-13-2008, 03:46 AM   #11
how is a shimmed vlsd for daily driving? I'm getting sick of my welded diff since i only daily drive the car now, is it anything like a welded? Also, what are the long term ill effects of doing this to the diff?
quach is offline   Reply With Quote
Old 09-13-2008, 01:47 PM   #12
motegineon's Avatar
mine is exactly the same as a welded, but i have a lot thicker shims in mine than a lot of the people who just add a small on to tighten it up a tad, in that case it would feel just like a normal vlsd that just locks easier
Old 09-15-2008, 10:45 AM   #13
I added 1 shim a couple weeks and its pretty tight, mine had a ratcheting sound on slow tight turns, but after breaking it in and a lsd additive the ratcheting has almost gone but there is a ton more lock than i thought there would be. if i knew how much there would be i might have only replaced the shim other than adding 1. how was breakin for everyone else??? any noise or just some tire chirping??
breakneckspeeds is offline   Reply With Quote
Old 09-16-2008, 05:57 PM   #14
lazysk8er2's Avatar
Thumbs up
can anyone list the part number cuz the pics arent working for me if its on there gonan do this asap very much hating on my vlsd right now
lazysk8er2 is offline   Reply With Quote
Old 09-16-2008, 07:55 PM   #15
motegineon's Avatar
-Shims go up in 0.3mm increments from 0.8 to 1.49mm
38424-40F60 =0.80mm(same as in the picture)
38424-40F67 =1.01mm
38424-40F75 =1.25mm
38424-40F83 =1.49mm (the biggest)
Old 09-21-2008, 09:14 PM   #16
MunsonAuto's Avatar
Send a message via AIM to MunsonAuto
Will this work with a stock open diff. too?
www.tannermunsondrifting.com
MunsonAuto is offline   Reply With Quote
Old 09-21-2008, 09:28 PM   #17
motegineon's Avatar
no
msg length
Old 09-22-2008, 03:51 PM   #18
SoSideways's Avatar
I thought the viscous diffs just had viscous fluid engaging the plates inside the housing, thus transferring torque between the 2 wheels?
If so, there shouldn't be spider gears turning and being meshed and destroyed, no?
Old 09-22-2008, 09:19 PM   #19
kouness's Avatar
wow this is awesome.. i have a vlsd lying around.. i need to do this before i throw it into my pumpkin.. nice...
95 Nissan 240sx: Q45 brake upgrade, v'tund lip
kouness is offline   Reply With Quote
Old 11-12-2008, 02:53 PM   #20
bumping a good old thread..
just took my lsd apart, had a 1.25mm shim in there from the factory (odd) and I could only get a .80mm and a 1.01mm from nissan, i installed both of them... think its gonig to fully lock?
edit: Update...
here is a very easy trick that will save you a headake when installing the diff back into the pumpkin.
-lift the whole pumpkin up with all the bearings and spacers aligned. and drop it on the drive shaft end. ( a nice 1 foot drop)
-use a phone book or somthing to drop it on.
-the impact(s) will pull the lsd bearings and spacers all into place effortlessly.
(took me about 4 drops and i couldn't believe it was that easy. lol
first impressions.. (awesome) It was fully locked but i did a few figure eights and it loosened up a bit. feels perfect.... super tight.
Chrischeezer is offline   Reply With Quote
Old 11-13-2008, 07:38 AM   #21
aziankingz's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
^ you wanna help me do mine lol?
aziankingz is offline   Reply With Quote
Old 11-13-2008, 07:52 AM   #22
SoSideways's Avatar
So I guess you can get buff while doing this too huh?
lol
The diff is like 100 pounds hahaha
Old 11-13-2008, 07:59 AM   #23
smelly240's Avatar
i have this in my car as well.
best 4$ ever.
they're special order sometimes - i have an extra if anyone cant get a shim.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 11-13-2008, 09:09 AM   #24
sure, pm me
Old 11-15-2008, 11:38 AM   #25
s13dan's Avatar
Tourqe specs for ring gear?
hey my VLSd (I know for sure its lsd)dosnt work at all never has no matter what fluid i use... So do you guy think i should just get the biggest shim. Im doing this asap ill be waiting on the dealership im sure.
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 11-16-2008, 08:49 AM   #26
RUTH'LESSDET's Avatar
Send a message via AIM to RUTH'LESSDET
im all over this!!!
91 Sil80-Sold, LS2 Powered 1997 240sx-Traded, 2005 350z-Sold, Whats next?
RUTH'LESSDET is offline   Reply With Quote
Old 11-17-2008, 02:56 PM   #27
just wondering...
after shimming your LSD, does anyone get a slight whine/rolling noise from it? its not loud, but its definitely audible.
Old 11-17-2008, 03:06 PM   #28
Jtuned_andy's Avatar
That whine/rolling noise is probably from improper gear mesh. I can't see how this is any good for the gears inside your differential.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 11-19-2008, 12:23 AM   #29
s13dan's Avatar
for real though anyone got them???
Old 11-19-2008, 08:49 AM   #30
smelly240's Avatar
impact wrench blast :P
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/s-chassis/200226-shimming-r200-j30-vlsd.html
Posted By For Type Date Hits
www.BURNOUT.lv • View topic - Coss_boy: Ford SIERRA This thread Refback 05-18-2012 02:23 PM 46
5earch This thread Refback 04-18-2012 02:06 AM 1
Nissan 200SX Club - South Africa | View topic - sale/swop lsd This thread Refback 04-16-2012 03:04 PM 1
This DIFF can get interesting.... | MNSubaru This thread Refback 04-14-2012 07:33 PM 1
Traction Optional :: View topic - [j30] Differential Shimming This thread Refback 04-09-2012 12:28 PM 2
cars cars cars | Teknoscape This thread Refback 03-19-2012 08:50 AM 3
www.200sx.cz :: Zobrazit téma - Diferak aneb kolecka se toci This thread Refback 03-12-2012 06:36 AM 1
besoin d'aide pour achat dun DIFF This thread Refback 02-20-2012 10:39 PM 4
Traction Optional • View topic - [j30] Differential Shimming This thread Refback 02-20-2012 09:20 AM 10
Dr Jeckyll - Page 3 - Alabama Region Sports Car Club of America This thread Refback 02-17-2012 08:08 AM 3
S13 VLSD shims for autocross - Nissan Road Racing Forums This thread Refback 12-28-2011 04:22 PM 2
240SX.net • View topic - A splash of cinnamon!!1!!11! This thread Refback 12-14-2011 01:22 PM 1
s14a kuro black - Page 5 This thread Refback 11-19-2011 09:49 AM 2
Car info / guides / how-to « MidNightSkanks This thread Refback 11-14-2011 06:55 PM 1
Club 350Z Espaa :: Ver tema - Brico grupo corto y diferencial autoblocante. This thread Refback 11-09-2011 02:20 PM 4
Diff's? - Page 2 This thread Refback 10-14-2011 08:54 PM 10
Diff's? This thread Refback 10-14-2011 08:42 PM 11
Nissan 200SX Club - South Africa | View topic - 1994 S13 LSD This thread Refback 10-10-2011 04:41 AM 4
S13 - Boostcruising This thread Refback 10-08-2011 07:33 PM 2
www.200sx.cz • Zobrazit téma - Diferak aneb kolecka se toci This thread Refback 09-20-2011 11:23 PM 6
Pros and cons of a welded diff ? - Page 3 This thread Refback 09-20-2011 11:12 PM 10
LSD question - Page 3 - SFLDrifters.com This thread Refback 08-26-2011 09:35 PM 15
need help with r200 diff - Hardtuned.net This thread Refback 08-20-2011 12:56 AM 10
s15 helical LSD "shimming" questions! - Hardtuned.net This thread Refback 06-12-2011 07:20 AM 14
High lock diffs - Page 5 - R3VLimited Forums This thread Refback 05-18-2011 11:08 AM 9
Rear LSD upgrade for less than 30 pounds This thread Refback 04-19-2011 07:21 AM 9
Adding shim/washer inside VLSD diff? - MY350Z.COM Forums This thread Refback 04-14-2011 12:46 AM 1
NCDrifters.com • NC Drifting Community This thread Refback 04-12-2011 11:35 AM 4
Welded vs tomei 2way - MY350Z.COM Forums This thread Refback 03-31-2011 04:35 PM 8
www.200sx.cz • Zobrazit téma - Diferak aneb kolecka se toci This thread Refback 03-28-2011 07:11 AM 1
s14a pern simmaus This thread Refback 03-08-2011 02:29 AM 79
S13 - Boostcruising This thread Refback 02-26-2011 05:26 PM 19
S14 Diff options for s14 W/abs? - 240sxONE Forums This thread Refback 02-24-2011 03:14 PM 25
GTUs Viscous LSD shim mod? - RX7Club.com This thread Refback 01-29-2011 05:45 PM 3
www.200sx.cz • Zobrazit téma - Diferak aneb kolecka se toci This thread Refback 01-29-2011 11:25 AM 2
www.200sx.cz • Zobrazit téma - Diferak aneb kolecka se toci This thread Refback 01-20-2011 05:39 AM 1
www.200sx.cz • Zobrazit téma - Diferak aneb kolecka se toci This thread Refback 01-20-2011 04:33 AM 1
www.200sx.cz • Zobrazit téma - Diferak aneb kolecka se toci This thread Refback 01-19-2011 07:21 AM 44
Shimming rear VLSD - NASIOC This thread Refback 01-12-2011 07:29 PM 19
KCDA-Online • View topic - Project:Pirate13 New Stuff Dec 29 This thread Refback 01-11-2011 08:45 PM 6
Club-S12.org v3.0 - Z31 Lsd This thread Refback 12-31-2010 01:08 AM 4
Tipos de diferencial autoblocante - Página 2 This thread Refback 12-24-2010 04:47 PM 1
Club-S12.org v3.0 - Lsd Swap This thread Refback 12-20-2010 06:06 AM 5
[S13] tantisimo ruido hace un LSD - Pgina 2 - ClubJapo. Portal de coches japoneses This thread Refback 12-13-2010 08:43 AM 3
Por fin, las famosas arandelas (s14) - Pgina 2 - ClubJapo. Portal de coches japoneses This thread Refback 11-12-2010 12:08 PM 7
vlsd problem? This thread Refback 10-25-2010 05:28 AM 9
j30 Vs. welded dif? - Page 3 - SFLDrifters.com This thread Refback 10-24-2010 11:46 PM 29
Tipos de diferencial autoblocante - Página 2 This thread Refback 09-26-2010 02:57 PM 2
Good Luggage Crew - Turbo Eunos Roadster NA - Page 6 - driftireland.com This thread Refback 09-21-2010 11:13 AM 15
Club-S12.org > Z31 Lsd This thread Refback 09-08-2010 02:05 AM 1
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
