04-20-2008, 03:08 PM
| Leaky Injector
| SR S13 Upper Engine harness problems OK so a few weeks ago i went to start up my car. When it FINALLY started it sounded like a WRX, which at that point i thought a coil pack had gone bad, so i popped the hood and changed out packs with some extra ones that i had. Started back up, still sounded like a WRX. So i started to unclip the injector harnesses, check first and second with a noid light, and both fired fine, got to the third, and no signal. I check all my ground, switched the ECU with one that i knew was good. Still nothing. Im stumped, i have checked the injector it self and its good. Has someone had this problem before? HELP!!! |
