| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia Member ![]() | instrument cluster problem. i have a 91' 240sx se. I got the car stripped clean of engine and chassis harnesses, it did however have interior dash harnesses. Anywho, I installed a chassis harness a few hours ago, and it works, however the car doesnt seem to want to cut off (or atleast the lights on the instrument cluster) don't want to cut off after i take the key out. Anyone know what this is caused by and how to fix? Thank you! |
| Sponsored Links | |
| | #2 |
| Leaky Injector | well seeing as the lights for the cluster only comes on with the headlights...maybe ur switch is bad? check youre switch, does ur 91 have daytime lights? maybe some of the wiring is hooked up wrong..or it could be touching a naked wire witch is energizing them.... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
