| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia Junkie ![]() | there is a lot of oxidation on my carbon fiber hood. i dont know what is the best way to get it off. i applied Meguiars wax or polish i wasnt sure. But that only worked for like 20 mins. Then it came back to it the oxidation form again. Thanks. |
| Sponsored Links | |
| | #3 |
| Nissanaholic! ![]() | Not a tech question, this should be in chat. The epoxy got old and yellowed. You can try to buff off the oxidation, but you're probably going to have to paint your hood.
__________________ Your copycat car reflects your copycat life. Banned- Calguns.net 1/4/09 |
| | #4 |
| Zilvia FREAK! ![]() | wet sand with 600 grit, get it nice and flat, and then respray with clear. 3-4 coats. then color sand and buff. |
| | #5 |
| Zilvia FREAK! ![]() | ^ what he said but x2 on the amount of coats. Look at EVERY SINGLE Evo wing, the same shit.
__________________ Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
| | #6 |
| Zilvia Member ![]() | yeah if the oxidation is not too bad like it was on my hood, you can either wetsand as previously mentioned or a good scrub with rubbing the polishing compound followed by a coat of wax should do the trick.
__________________ http://s165.photobucket.com/albums/u63/ajhartma/ 1990 240sx hatch....currently monster truck status, with sunken battleships. ![]() *Junkyard Scavenger* |
| | #8 |
| Good touch/Bad touch ![]() | yeah cf hoods are bad about that. they dont have clearcoat actually, when you buy them. they have a gel coat. It oxidizes really freakin easy. Personally, my preference, paint it. CF is cool and all, but when 5-0 sees a cf hood they keep an eye on you. |
| | #9 |
| Zilvia Junkie ![]() | Correct me if I'm wrong but isn't colour sanding the same thing as wet sanding?
__________________ Visiting From UpNorthImports.com |
| | #10 |
| Post Whore! ![]() | color sanding usually refers to single stage paint... where a car is newly painted but has a orange peel look, what u do is take it down with 1000-1500 real quick and finish it off with 2000... and polish it with a cutting compound.... this is also refer'd as a cut & rubb.... this is also done to 3 stage paint where clear coat is used... so yeah ur right...
__________________ S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
