Old 04-03-2011, 08:51 AM   #61
ericcastro's Avatar
Originally Posted by sidewaysil80 View Post
i have a freshly shimmed helical (they're good i measured lol) sitting in an r200 housing w/ proper output shafts and ready to roll. you would have to swap diff covers but if you want i'll mail that bitch to you on monday. only thing is i'm balls deep in a build and broke so you would have to cover s/h.
Thats a lot of weight to ship.
any idea the cost?
im in 90029.
Originally Posted by soreballz View Post
If you want to juice the KA (and have it last), you'll need some tuning. Different plugs, timing changes, etc. PM CodyAce. He might be able to give you some advice on the squeeze.
I'd suggest trying to find a 4.6 r&p to help compensate for your lack of power. It won't do you any good for the standing mile test, but it will definitely help your drag and road course times.
Hmm, having to tune sounds like money.
4.6 r&p ??
Originally Posted by DMiller View Post
run an automatic ECU to get rid of speed cut, i ran one in my old s13 when i had the sohc, still has factory rev limiter, just no speed limiter and runs richer on decel so you will here popping on throttle lift at higher rpm.
nitrous install info: NOS Install (keep in mind, this is for a WET kit, DRY kit's are simpler but tend to have uneven NO2/FUEL distribution, which can hamper performance and reliability)
also pick up whats called a "window switch" which is wired into the nitrous setup, it is an RPM activated switch so that you don't accidentally bury the rev-limiter with nitrous spraying and grenade the engine.
Thanks, i will go over this tonight.
Originally Posted by cordobes View Post
i dont think u need to launch in 2nd gear with a stock ka..and if u put nos.. make sure the engine is gonna last for the other games ,lol
I didnt mean launch second, i meant hit the nos in second, since the first gear is strong, and the cars top end is where it sucks.
I do have a tuned ECU in it right now.
No idea what it is.
Came from sideways performance.
They did a swap and it came off the sohc, they gave it to me for free.
Seems to give the car some more ponies, but does make it run hotter.
Think it says python or something on the sticker on the side.
ericcastro is online now   Reply With Quote
Old 04-03-2011, 08:57 AM   #62
sidewaysil80's Avatar
i can't imagine it being that much through greyhound. i'll get it weighed tomorrow and get an estimate.
www.sumospeed.com
THE Powertripper
sidewaysil80 is offline   Reply With Quote
Old 04-03-2011, 08:59 AM   #63
ericcastro's Avatar
cool, thanks man
i know its a little work on your end, i appriciate it.
(and tried 3 times, and still cant spell that word, to early, off to the track again.)
Old 04-03-2011, 12:59 PM   #64
soreballz's Avatar
4.6 r&p ??
4.6 ring and pinion gears for the diff. Stock is 4.08. IIRC, the 4.6 comes from the front diff of certain year Xterras. That's just what I've read, though.
It'd probably be easier to track down a 4.36 r&p.
The higher the number, the faster you accelerate. It will lessen your top speed as well, but that won't matter much with an n/a KA.
Read this:
http://www.ka-t.org/forums/viewtopic...d5c0ff8730bf42
Nitrous can be a tricky thing for beginners. I bet there's threads about it on KA-T.org.
-Kyle
Old 04-03-2011, 06:57 PM   #65
Send a message via AIM to DMiller Send a message via MSN to DMiller
No idea what it is.
Sounds like a basic advanced timing and slightly modified generic rom tune for NA cars. If you plan on spraying it, go with stock ECU and retard ignition timing by roughly 1 to 1.5 degrees timing per 50 HP sprayed, drop to a colder plug gaped closed to .025″-.030″ and after your first test run on spray, check the plugs and make sure they are reading good and not running too lean.
DMiller is offline   Reply With Quote
Old 04-03-2011, 07:16 PM   #66
SR20 Air Conditioning Man!
codyace's Avatar
Trader Rating: (38)
Feedback Score: 38 reviews
Easy one first: 4.6 final drives come out of the front differential of the early/first gen Xterra SE's. THey also had 4.9 in them, however I'm unsure if that 4.9 differential is the same as the r200 RP set. REgardless, a 4.6 will really wake the car up, but will eat some top end...but with a SOHC KA, it's not like you're going to be going fast anyway.
Now into nitrous:
How 'involved' do you want the nitrous setup to be? Do you want to run a basic dry shot, or take a risk and maybe run a Wet setup? As mentioned directly above me, it would be nice to know what the ECU was setup for (in regard to base timing, fuel required etc etc) but in the grand scheme it's not going to be anything substantial (if I were to assume)
To me, I'd suggest a wet setup simply due to the fact that you're relying on pisswater for fuel. If it was just to make a few balls out passes, it would be one thing to run it but to last is another. Certainly it involves adding a fuel cell for the fuel, a second pump, and wires...but it's all super easy! A generic external fuel pump works great (gravity fed of corse) as long as you know the maxium fuel pressure of it (so you can get accordingly)
With the wet kit, you could also get away without retarding that degree of timing IMO. THis will work out nicely 'overall' as you won't be down so much powerwise when not using it. If using a dry kit, I'd say to certainly pull a degree.
Regardless of the setup, DMiller is pretty spot on with the plug choice, as well as the advice in general. It would be nice to have a dyno available to really set in the jetting for it, but street won't hurt either. You'll be surprized that 'more nitrous' doesn't always mean more hp (but makes for some nasty puddeling/explosions).
Reliable: 50hp wet
Testing it: 70/75 hp shot, pull some timing or 50 hp dry (if you really wanted to get wacky you could spray before the MAF and see if it will correct it any for you...any little bit may help haha)
Gonna make some power, but puke all over the track eventually (or blow intake parts off): 100 hp wet. Gotta think they make 120-140 'stock/bolt ons' and you can rarely double stock engine power wheel output ...but man it will RIP.
I'm a bit tired from 3 days of field training, so this may be all over the place. I'll re-read this again tomorrow and see if I forgot anything.
In the
codyace is online now   Reply With Quote
Old 04-03-2011, 08:45 PM   #67
word sux's Avatar
thats awsome
single cams are cheap as fuck anyway. its better to burnout then fade away!
word sux is offline   Reply With Quote
Old 04-03-2011, 10:30 PM   #68
Oilcover's Avatar
Send a message via AIM to Oilcover
I was castro's secret weapon today!
I'll let him tell the story. . .
|HotLine Performance|Falken Tire|Exedy Clutch|DSTROYR|Factory 83|326power|
Oilcover is offline   Reply With Quote
Old 04-03-2011, 11:03 PM   #69
ericcastro's Avatar
Shit man, check this out.
Everyone wanted to contend, or whatever its called.
So they go back through the tapes, and they flagged me at 9 laps on oval, not ten !!!!!!!!!!!! (everyone supposed to do ten)
But now they think they did it to others too, so we wont know the results till later.
Talk about bringing me down though, totally bummed the rest of my day.
BUT,
Your advice about the really late apex totally worked and compensated for the welded diff trying to push me in the corners.
Oval grip was actually pretty fun, totally different driving exp.
And I dont think i could have gone faster with the SOHC.
I may not roll the dice on the NOS now because they did a short drag tonight at the end of the day.
And there is no reason to use it for the top speed/mile challenge.
IF we do mohave mile for top speed.
and i say IF, because this shit is changing so fast.
If we do, my car tops out at 115 (fuel cut), at around 5 grand.
So If I pull the speedo, I will only be able to get another 1,500 RPM's out of the engine anyways.
If i can run a "16 second quarter mile at 85ish mph,", then i should be able to top my RPM's out.
So with the speedo cable off the tranny, does the tac still work, so i dont grenade it?
The rest of the events are more standard grip stuff.
So I am gonna try and borrow a diff if that one from PA wont make it or is to much to send.
man, wish R comps werent so expensive.
Who has a set for sale cheap?
or to borrow? lol
Im on 17x9 all around.
They also wanna do the events next weekend too, so maybe no FD long beach, im gonna be so bummed.
Old 04-03-2011, 11:07 PM   #70
ericcastro's Avatar
Oh yeah, yesterday, I bent a inner tie rod, replaced it, and used a measuring tape to line it up.
So the whole weekend was done with that alighnment.
On the last 2 miles home tonight, something got loose and the front steering feels funny again
Gotta check what moved or loosened, re-align it with the tape, and feel it out .
Old 04-03-2011, 11:41 PM   #71
just disconnect the speed sensor wires, the tachometer will still work you just wont have a working speedometer
what size tires?
asking for top speed purpose, because with 205/40R17 you should be able to top out at 147mph before factoring coefficient of drag and wind resistance
if you can step up to 225/45R17 even in just the rear, you will top out 5th at 156mph (this is all based on stock KA trans gear ratios and r&p gear in the diff) before factoring coefficient of drag and wind resistance
Old 04-04-2011, 07:18 AM   #72
ericcastro's Avatar
what size tires?
Im on 40 series 215's right now.
But I do have my heavier set of 17x9's, and i think i have some larger series tires.
will look after work.
Old 04-05-2011, 11:10 AM   #73
silsx13's Avatar
Send a message via AIM to silsx13
Eric, I have a set of USED (35-45% tread left) Star Specs in a 255 40 17 size if ya wanna use em....
I know they're not R-comps but it's better than nothing at this point and you can have them for FREE. Just gotta pick them up....
Call or PM me back sir.
Blog: http://hartapexlife.blogspot.com/
silsx13 is offline   Reply With Quote
Old 04-05-2011, 01:10 PM   #74
ericcastro's Avatar
^ I will stop by the shop today and talk with ya
thanks.
Old 04-05-2011, 05:56 PM   #75
ericcastro's Avatar
I got some tires from Jon (silsx13)
will be getting them mounted in the morning.
figuring out what got loose on the drive home in the front suspension.
Just need to track down a 2way or VLAD to borrow this weekend?
Anyone?
Old 04-05-2011, 06:11 PM   #76
Send a message via AIM to vboy720
i was on judge judy, and my s14 was shown on it too.
vboy720 is offline   Reply With Quote
Old 04-06-2011, 01:24 PM   #77
ericcastro's Avatar
This coming Sunday is the last racing day.
I need to borrow some sort of Diff from someone.
2 way, 1.5, or especially a VLSD please.
Thanks.
Old 04-06-2011, 01:48 PM   #78
itwillboost's Avatar
You said you have a tuned ecu. If you can hook it up to a laptop and see if you can unlock it. Alot of time these ecu's have software which can be located online and this can be beneifical to you. It's wont do a ton, but it will give me a bit more hp and get rid of your top speed limiter safely.
itwillboost is offline   Reply With Quote
Old 04-06-2011, 01:57 PM   #79
stiizy's Avatar
reality show? E really? are you selling on me bro??
Old 04-06-2011, 04:39 PM   #80
fckillerbee's Avatar
Send a message via AIM to fckillerbee
did you welded break?
Vildini Motorsports, Orange CA.
Old 04-06-2011, 06:48 PM   #81
ericcastro's Avatar
No, but we are down to
Mohave Mile top Speed (unhooking speedo from tranny, should get about 130-145 mph)
HTM time attack
Streets of willow.
Chicago box (??)
I have some used R-comps, so i need a diff.
The welded is fine, but pushes and creates understeer in the corners.
A different diff and the tires should pick up a few seconds and show what a driver can do with a 22 year old car, 140hp and a build budget of $5,500 for the car.
Would be nice to win this thing.
Old 04-06-2011, 06:53 PM   #82
ericcastro's Avatar
I am also tapped out on money, since i am replacing my steering rack (it finally broke).
And prolly the high pressure line (cost depending)
anyone mount and balance for free,
Was gonna put the Rcomps on my current rims, and my feds on those chrome ones i have.
Will prolly drive on the chrome to the track, and put the rcomps on and remove my rear over fenders to clear,
Road warrior time on these fools !!
Old 04-07-2011, 05:57 AM   #83
Walperstyle's Avatar
Send a message via MSN to Walperstyle
Wish I lived near you, with this time off work, I wish I could help!
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 04-07-2011, 07:00 PM   #84
ericcastro's Avatar
Look at who checked in after a several year break, lol.
whats happining man?
so i got the new rack in.
Alighnment is coming saturday as well as all the tires o have on, going to the heavier chrome rims i have.
And i will be putting used DUNLOP Direzza sport Z1's on my lighter rims.
255/40, 17.
Gonna pull the over fenders off the rear so they fit.
just waiting on a Diff to borrow????????????????????
Old 04-07-2011, 09:55 PM   #85
ericcastro's Avatar
Got a Helical coming on loan for a week.
Some water wetter and coolant and i think i am set.!!
Old 04-07-2011, 10:29 PM   #86
Quick, jack up your car and disconnect all the plugs from your trans that aren't the speed sensor. I think the single cam has a 4th and 5th gear sensor, then the reverse switch. If you know which ones are 4th and 5th, just disconnect them. But, the ecu limits REVS in 4th and 5th, NOT SPEED. If you have time, and a buddy, you can check which one is reverse and leave it plugged in. (It might be dual cam trans that have 4th gear sensor, I can't remember.)
GT2560KA24DE & GT2560SR20DET, still on the fence.
mikerbike is offline   Reply With Quote
Old 04-08-2011, 03:24 PM   #87
spoolandslide's Avatar
Location: lost in a bump splice in the fabric of our clockwork
It's not how you stand by your car, it's how you race your car.
Get some Eric.
www.theworldidealized.blogspot.com
spoolandslide is offline   Reply With Quote
Old 04-11-2011, 12:24 AM   #88
Heard you did the standing mile at 106mph today, not a bad standing mile for stock KA with a chipped ECU
edit: Just saw the comment on the speedhunters photo. shame revs cut out on ya, I think it might have been what "mikerbike" was saying about 4th and 5th gear sensors cutting revs. I 've never had 4th and 5th gear sensors to tell if thats what limited speed, always thought it was speed sensor signal.
Old 04-11-2011, 12:38 AM   #89
ericcastro's Avatar
yeah, I was maxed out at the 3/4 mile mark. would have been real nice to actually be able to take it to 5th gear redline.
unhooked the sensor wires from the tranny on the second run, and ran the stock ECU.
The RPM's cut on my, lol.
Awesome event to go to, such amazing cars.
plus making the speedhunters facebook page was cool, and meeting Linhbergh at the track. A friend text me the screen shot while i was there, and i figured it must be the photographer with the Aasbo, "Hold Stunt" tshirt
facebook link
Speedhunters's Photos - Wall Photos | Facebook
My car at willow today.
Login | Facebook
Click the image to open in full size.
you can see where i had to hammer the shit out of the firewall to fit those 255's with my 38mm spacers.
Not used to running Direzzi's or being on a Helicol diff.
Takes some practice. Did ok though.
Old 04-11-2011, 12:39 AM   #90
KOME's Avatar
Get VTEC bro
KOME is offline   Reply With Quote
castro
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
