| Off Topic Chat All non related chat goes here. |
| | #1 |
| Zilvia Member ![]() | DIY powder coating oven damn, sorry about the double post first time welding, so bear with me 0 dollars spent.... free oven off craigslist ![]() ![]() ![]() this is from using just the oven itself so far, i will be doing supports and possibly a insulation layer the right side will have a viewing window made from glass welding sheet metal sucks! so far its just tacked together, ill be sealing it up soon its a double oven im using, so it should work out, need to make a skeloton frame inside though with hangers ill be purchasing a eastwood kit and i own already a 33 gasllon craftsman air compressor anyone with experience have ideas? this morning i added the start of supports. my welds suck. im trying to get better, butt this sheet metal isnt the thickest most deffinetly entertaining a insulation layer to retain some sort of heat ![]() the BAM. 3 seconds it took me. (maybe a little bit more) ![]() ![]() ![]() will be using the other door on the bottom if it fits, or ill extend the one on there and the pole across is where ill be hanging shit the welding is slowly getting easier and the swivels. hold the door,so i say im doing a decent job some more information on the DIY part heres the stock fan ill be using, this stays internal and is made from metal to withstand heat ![]() heres some free insulation, from the stock oven i can use ![]() here are the heat rails, off the harnes, its as easy as a pos. neg. wire that attaches to them. simple stuff, i have 4, becuase i have a double oven ![]() heres the wiring mess, i touch NOTHING, this is literally the top of the old oven, i welded it to the top of my new one ![]() that harness, has a sister harness that scrolls down the back of the original oven, dos the same as mine consists of A powe harness, like any eletrical oven ![]() and B the wiring to each heat rail, pos. neg. and to a light, which ill use, and to a fan, that i might not use ![]() looking through a hole, heres my space ![]() ![]() heres my beefy wooden pallet, i took from my job, ill be putting roller wheels on it ![]() that wood will get hot, so i must make a pad, i have spread rock, to seperate the wood from the oven ![]() not recommended, its expensive but i got it for free[hr] and then some tools used 30 dollar drill from hb freight ![]() 20 dollar cut off wheel from hb frieght ![]() and what do you know a pheumatic 12 dollar cut off wheel for the small stuf, also from hb freight, all work great. ![]() welder being used is a lincoln 100 weldpack, purchased for 120 bucks Update** put an hour or two into it this morning heres what i did, i added the other door, and welded them together, and added a 3rd swivel ![]() ![]() i also realized how flimsy it was getting with the heavy door so i bridged the two together with a pipe ![]() im buying sheetmetal soon, but i forgot this project is about buying the least i can, soooo back to milking what i can out of the stock oven........... ![]() you know what sucks guys? owning 1 vicegrip.... and trying to weld and hold shit by yourself FUCK haha ![]() ![]() having all those open spaces is +1 will allow me to add insulation before i button it up speaking of insulation, so far im buying none. im using the stock ovens insulation ![]() and tip of the day! TAPE ANY SHARP METAL STICKING OUT ![]() ![]() dont worry i have my tetnus shot |
| Sponsored Links | |
| | #2 |
| We're watching you. ![]() | Uh, props for trying? I would've used the oven in "stock" form to powdercoat smaller things first. Make some money off of it. Then, the money made from that would go into purchasing a real oven. But, yeah. That looks ghetto as hell.
__________________ ![]() -Angry Panda Fabrication - Fixing iDesigns shitty work since 2008. CrimsonRockett@blogspot Need body work/paint? PM me. |
| | #4 |
| Zilvia Member ![]() | yea dude, this looks SCETCHHHH as all hell...Make sure you alt least isolate those connections on the top of the oven before you short something out or better yet electrocute the crap out of yourself... Props for effort tho! You need to get some insulation in there tho...its not going to hold any heat in there with it sitting like that....looks like you just tac welded all the stuff together... |
| | #6 | |
| Premium Member ![]() | Looks like a possible fire hazard.
__________________ ZOMG A NEW FORUM BY THE CREATORS OF ZIVLIA?!!! Join us at http://boostaholic.org/ Become my pupil Future240 My Brute Become part of the Zilvia Clan http://mybrute.com/team/8715 Quote:
| | #7 |
| [JEFE S14] ![]() | I'd say it's almost impossible for this not to be a fire hazard. Good luck? |
| | #10 |
| Zilvia Addict ![]() | Haha. Do you have a fire extinguisher handy? I don't think I would trust this. But props for at least trying.
__________________ Blow me, bitches. Last edited by Slammed180; 07-14-2009 at 10:42 PM. Reason: Fucking spelling! aghhh! |
| | #14 |
| in training ![]() | Oh wow. the DeLorean picture is killing me! anyways, give it a test run and show us what you're produce turns out like. it looks sketch as fuck, but hell it might work....
__________________ |
| | #15 |
| Zilvia Addict ![]() | That looks like its going to burn your house down fuck it looks dangerous props for being down to do this though |
| Sponsored Links | |
| | #17 |
| Zilvia Member ![]() | hey, does it look anywhere near done? no... lol, i am building the oven as we speak and yes, i started the project awhile ago, i am buying new sheet metal and a kit soon to continue the build as long as i seal it, explain how it will be a fire hazarD? ill be doing it outside anyways |
| | #21 |
| Post Whore! ![]() | Try it outside the first couple times. AWAY from the house. lol
__________________ My 240 vBgarage |
| | #22 |
| Premium Member ![]() Join Date: Sep 2005 Location: Feasting on the flesh of the guilty, and drinking the blood of the innocent (714)
Trader Rating: (11) | good luck with that.
__________________ -Carlo ![]() FS: My Black S14 http://zilvia.net/f/cars-sale/280566...sx-7500-a.html -Go ahead, buy it! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
