| Mid-Atlantic States DC, Delaware, Kentucky, Maryland, New Jersey, New York, Ohio, Pennsylvania, Virginia, and West Virginia. |
| | #1 |
| Zilvia FREAK! ![]() | I'm in richmond, va... I am making a bolt on bracket kits for the Quest Minivan 125Amp alternator on RB25/Rb26s.... I want to start making kits for the SR20DET... I just need somebody with an SR, who has time and patience for me to design bracketing to suppport the quest alt. on an SR.. Reward is a quest alternator and bracket kit installed for $30.00... all for being patient. It may take a half day at the most... but i don't mind somone hangin out while I do this. Radiator may and or fan and fan shroud have to come out. The benefits of the quest alternator are endless, you can support any fan setup, great for running taurus fan on high speed. Good for sound systems/big fuel pumps/ and any extra loads you're putting on your stock alternator. Remember the SR alt was only sized for a motor with a clutch fan and a dinky condensor fan. You don't want to be dropping your fuel pump voltage at high RPM, or induce weaker spark, so this is definitely a mod anyone should consider. I am also interested in anyone with SR ac compressors.. I am starting to fab adapters that go from sr ac compressor to usdm 240sx ac lines. I just need initial measurements so i can throw in my cad drawings. PM ME if interested! Last edited by opponheimer; 02-18-2009 at 08:26 AM. |
| Sponsored Links | |
| | #3 |
| Has a Premium Member. ![]() | also Mid-Atlantic 240SX
__________________ ![]() ![]() |
| | #5 |
| Premium Member ![]() | if you do make the bracket let me know im in for buying one... |
| | #7 | |
| Leaky Injector | Quote:
I have a 93 s13 with SR20. I also have the AC Compressor installed using the KA mount. I am using the KA compressor because it hooks to my AC lines. I would think you would rather want to make a bracket to install the KA compressor on the SR block. Easier to find KA ac compressor then SR compressor and cheaper. I live 2hrs outside of Richmond. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
