Zilvia.net Forums
Go Back   Zilvia.net Forums > Local / Regional / National > USA > Mid-Atlantic States
Mid-Atlantic States DC, Delaware, Kentucky, Maryland, New Jersey, New York, Ohio, Pennsylvania, Virginia, and West Virginia.
Old 04-27-2008, 06:08 PM   #1 (permalink)
need help, car not starting
does anyone have a harness for an sr that I can use to see if the car would start up...I did a swap and the motor is cranking but doesnt start, I tried changing the starter chip, etc.. and the last thing that i can think of is the harness being messed up during the swap....any help would be good
thanks, Im located in annandale
1sloREX is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 04-28-2008, 09:49 AM   #2 (permalink)
elfenguard911's Avatar
just remember air,fuel and spark
[/SIGPIC]meow mix or kibbles & bits? try to b***h now
elfenguard911 is offline   Reply With Quote
Old 04-28-2008, 12:39 PM   #3 (permalink)
there is spark, just a little weak, and def. there is fuel
Old 04-28-2008, 01:47 PM   #4 (permalink)
Phil703's Avatar
Hm.. Double check all connections, Make sure your plugs are good, make sure the wires are good..
Pm me your address I may be able to swing by sometime today or tommorow.
Phil703 is offline   Reply With Quote
Old 04-29-2008, 02:18 PM   #5 (permalink)
i really want to get this car started....im willing to pay if anyone can get this car started
Old 04-29-2008, 04:11 PM   #6 (permalink)
Phil703's Avatar
I'll come over tommorow. Im bed ridden sick today, Most def tommorow.
Old 04-30-2008, 10:17 AM   #7 (permalink)
where are you exactly?
Old 04-30-2008, 10:30 PM   #8 (permalink)
annandale, va
Old 05-02-2008, 07:33 AM   #9 (permalink)
ouch thats a 2hr drive for me man sorry i would love to help though. all i can suggest without seeing it would be if its a modded sr harness with the ka terminals then check for any shitty solder jobs and the ENTIRE!!! starting circuit for any bad grounds or anything. i have a bud who recieved a bad maf and computer so check those out aswell.
lemme know how it turns out.good luck
Old 05-05-2008, 03:13 PM   #10 (permalink)
thanks for the advice...im looking to try out the harness as soon as my finals are over
Old 05-20-2008, 08:11 PM   #11 (permalink)
FTP
aNskY's Avatar
Send a message via AIM to aNskY
weak spark on all cyls? i had a similar problem, my ignition outputs from ecu were mixed up. probably not your case but check for any splices
aNskY is online now   Reply With Quote
Old 05-21-2008, 09:04 PM   #12 (permalink)
My Trq Rench is Bggr thn Yourz
minisilvia's Avatar
Did you make sure your cam angle sensor is lined up?
20LBs to Glory
minisilvia is offline   Reply With Quote
Old 05-23-2008, 10:02 AM   #13 (permalink)
yea i do line up the cam angle, and as far as the ecu wire splice, im running a power fc and i tried hooking it up to the power fc and the ecu....im probably going to take the car to BT motorsport for them to check it out
SEO by vBSEO 3.2.0
