Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Group Buys
Group Buys Dedicated Forum for Group Buys.
Old 07-01-2006, 06:12 PM   #1
CPARKPowertrix's Avatar
SALE: NOW OFFERING RPS CLUTCHES and FLYWHEELS with FREE STEEL BRAIDED CLUTCH LINE
We are proud to now offer the complete line of world renown RPS Clutches and Flywheels. As our introduction to carrying this great line, We will also be offering our FREE Steel braided clutch line with purchase of any clutch within the month of July.
Also check out our other great Zilvia.net Specials:
ONE WEEK ONLY 4th of July SUPER SUSPENSION SALE w/ FREE BUSHINGS and FREE SHIPPING:
http://www.zilvia.net/f/showthread.php?t=113751
Suspension arm bushings, ball joints and subframe Spacers post:
http://www.zilvia.net/f/showthread.php?t=112702
****RPS SPORT STREET CLUTCH****
KA24:
ZILVIA MEMBER PRICING: $265.00 plus FREE STEEL BRAIDED CLUTH LINE.
List Price: $311.85
SR20:
ZILVIA MEMBER PRICING: $284.00 plus FREE STEEL BRAIDED CLUTH LINE
List Price: $335.00
Stock to moderate pedal feel. Most ideal for bolt-on performance upgrades (BPU) such as air intake, exhaust system, ignition system, fuel system and adjustable cam gears. Pressure plates are fully re-buildable
KA24: Torque Cap: 220 Pressure Increase: +15%
SR20: Torque Cap: 280 Pressure Increase: +17%
****RPS SPORT 6 Puck Sprung Hub Clutch****
KA24:
ZILVIA MEMBER PRICING: $361.00 plus FREE STEEL BRAIDED CLUTH LINE.
List Price: $425.00
SR20:
List Price: $425.00
Description: Stock to moderate pedal feel. Most ideal for bolt-on performance upgrades (BPU) such as air intake, exhaust system, ignition system, fuel system and adjustable cam gears. Quick engagement but smooth enough for street use. Pressure plates and discs are fully re-buildable
KA24: Torque Cap: 300 Pressure Increase: +15%
SR20: Torque Cap: 340 Pressure Increase: +17%
****RPS MAX Street Clutch****
KA24:
ZILVIA MEMBER PRICING: $380.00 plus FREE STEEL BRAIDED CLUTH LINE.
List Price: $448.00
SR20:
List Price: $448.00
MAX pressure plates offer 400 to 600 pounds of extra clamping force to hold your biggest power. Pedal feel is stiff to very stiff and engages smooth. RPS is the only clutch company with a U.S. Patent (#5,769,973) on their single diaphragm pressure plate technology. Our unique dual diaphragm technollogy allows us to create almost any clutch unit with any pressure ranging from stock to double stock in 100 pound increments.
KA24: Torque Cap: 400 Pressure Increase: +50%
SR20: Torque Cap: 475 Pressure Increase: +80%
****RPS MAX 6 Puck Sprung Hub Clutch****
KA24:
ZILVIA MEMBER PRICING: $433.00 plus FREE STEEL BRAIDED CLUTH LINE.
List Price: $510.00
SR20:
List Price: $510.00
KA24: Torque Cap: 475 Pressure Increase: +50%
SR20: Torque Cap: 550 Pressure Increase: +80%
****THE RPS CYN-R-G Patented FLYWHEEL****
Absolutely the very best flywheel you can buy.
RPS guarantees that all of the segmented wear surfaces are fully replaceable for the life of your car. CYN-R-G Segmented flywheels utilize our patented (6,793,057) "segmented" heat shield system.
Traditional heat shields warp because of the uneven heat produced by a slipping clutch. Just like a car going around in a circle, the outside tires go faster than the inside tires, the clutch disc slides faster around the outside of the flywheel than it does around the inside. The faster moving outside surface gets hotter than the inside surface. Because metal expands more the hotter it gets, the outside of the heat shield expands more than the inside. Traditional heat shields are made of one piece metal rings, so when the outside expands more than the inside, the only thing the shield can do is warp.
The CYN-R-G Segmented heat shields are not connected so they can expand and contract without warping. A warped heat shield causes the clutch to slip, which causes more heat and more warpage.
Our flywheels are typically 10 to 15 lbs. lighter than the factory units which allows up to 20 more HP to get to the wheels!!
FOR SR20DET:
ZILVIA MEMBER PRICING: $425.00
List price $500.00
Description: The last flywheel you will ever have to buy. The patented segmented heat shield design will not warp like other common one piece heat shields. RPS CYN-R-G flywheels are highly engineered with these benefits like dynamically balanced, crushed Heli coil inserts, stepped dowel pins, and over-sized lock-down bolts that are welded to the ring gear for positive retention.
Weight: 11 lbs.
Choosing the Right Clutch the First Time:
First and foremost you need to decide what you plan to do with your vehicle. Are you going to race the car or simply drive it on the street, or maybe both? The big difference h is, if you plan to race the car at ALL it will change the decision on what type of clutch disc you will require. Using a "street' disc for racing (drag or any type of slipping environment) will "glaze" the surface of this OEM type material. A street disc is made of organic material made for long life and smooth engagement. It is not in any way intended for drag racing as it can permanently damage any street disc.
A street disc combined with a high clamp load pressure plate (Max series) will hold good power once fully engaged. This makes the street disc great for road racing and normal driving with high power and also good for high speed freeway runs. Remember what the duty of your clutch CAN be, getting a 2400 lb car moving from a dead stop and spinning the flywheel at 4000 to 8000 RPM and wanting the two to connect. Using a smooth organic material will not going to work for long! Doing this will absolutely glaze the disc or tear it. Once the disc is glazed, it will no longer hold the same power and it will slip.
A 6 (or any #) puck disc is designed for this type of abuse. The 6 puck disc has a variety of different materials in it; which includes ceramic and brass. This material will bite harder and slipping it will not glaze the material, but will accelerate wear. Picture this type of disc as a sticky tire. It will stick and hook much better, but will wear out faster.
The 6 puck disc with the latest materials are lasting about 20K on average. Of course this all depends on your left foot AND if it is properly adjusted! A street disc when not drag raced can last about 40K on average in a high powered Z. The 6 puck material has come a long way over the years and it tends to last much longer now. They also have become much smoother as well. RPS makes the sprung hub 6 puck and it is very street able.
If you plan on doing any drag racing at all we would strongly suggest only a six puck clutch. For the ultimate hardcore drag racers, we ALSO recommend the Max series. The Max does have a slightly heavier pedal feel, but once again it is highly street able.
ORDERING AND PAYMENT DETAILS:
Please email me:
Name
Shipping address (for shipping quote)
Contact Number
Components wanted
Paypal payments:
If using a Credit card through Paypal use sales@powertrix.com Please add 2.9% for Paypal fees.
If transferring from Paypal to Paypal account use powertrixsales@aol.com (NOTE: This account will not accept Credit Card Payments.)
Or you can send a money order to:
POWERTRIX
Attn: Charles Park
9450 Mira Mesa Blvd # B 447
San Diego CA 92126
Please inform me if you are sending payment by mail and send it by means that are track able for your own protection. Example: any shipping company that will provide you with a tracking number or delivery confirmation.
Please feel free to call me with any questions you may have.
Charles Park - www.powertrix.com - 619-944-6055
CPARKPowertrix is offline
Old 07-02-2006, 02:41 PM   #2
Great prices for a very good clutch setup....
BTW:Are you guys able to sell just the Max pressure plate for the ka by its self?I already have a custom race disk and I'm in need of a strong PP....
pm me with reply,thanks in advance
Zilvia4eva is offline
Old 07-02-2006, 03:02 PM   #3
doc99's Avatar
How long will this deal be going on? Just till the end of July?
1990 Nissan 240sx LS1 Coupe - Loud, Runs, Drives, Loud
doc99 is offline
Old 07-03-2006, 06:15 PM   #4
scottieg240sx's Avatar
i would also like to know how long we have to make the purchase
scottieg240sx is offline
Old 07-04-2006, 12:54 PM   #5
Yes, The sale should go throught he end of July. Thanks.
Old 07-08-2006, 05:09 PM   #6
doc99's Avatar
Payment sent, thanks charles!
doc99 is offline
Old 07-08-2006, 08:18 PM   #7
I am assuming this is not a kit? so we need the throw out bearing and tool?
DaConfusion is offline
Old 07-10-2006, 05:45 PM   #8
The RPS clutches come with the Pressure Plate and Disc.
The RPS clutches come with the Pressure Plate and Disc. If you need the throw out bearing, We can also provide it as well they are $19-$29.00 depending on make, year and brand you would like.
Old 07-12-2006, 12:23 AM   #9
i rusn a rps sport puck clutch... and it's worth the money! grips hard and nice!
gettin' it sidewayzzz
decksy is offline
Old 07-28-2006, 04:43 PM   #10
tbowzer's Avatar
Send a message via AIM to tbowzer
sent inquiry to sales@powertrix.com....still no response.
Let me know.
tbowzer is offline
Old 07-31-2006, 11:31 AM   #11
Sorry for being out of touch.
Let me know.
Hello, Sorry for being out of touch. You can also contact me on my office or mobile phone.
OFFICE 858-566-5060
MOBLIE 619-944-6055
Old 08-03-2006, 10:03 AM   #12
Is this still going on at these prices, am considering buying a 6 puck sport clutch within the end of this month(August)...
Kouks is offline
Old 08-10-2006, 12:16 AM   #13
articdragon192's Avatar
No lightened flywheel for KAs make me sad
articdragon192 is offline
Old 08-10-2006, 05:08 PM   #14
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
fidanza makes a lite flywheel for KA
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline
Old 08-10-2006, 09:08 PM   #15
doc99's Avatar
yup ^^ that's what I'm using with my RPS
doc99 is offline
Old 08-14-2006, 10:07 AM   #16
Rps Clutch Sale Extended Until Further Notice
We will leave the Sale and specials open until further notice on the RPS Clutch and flywheels.
Also we are now offering the full installation kit which consists of pilot bushing, throw out bearing, alignment tool
Install kit: (pilot bushing, throw out bearing, alignment tool) $29.95 - $39.95. Depending on make and model.
Old 08-14-2006, 12:37 PM   #17
Is pick up available?
Old 08-14-2006, 12:44 PM   #18
Yes, local pick up in San Diego is possible
Yes, local pick up in San Diego is possible. Please let me know what product you need so I can verify stock. If it is not in stock, I can have it in 1-2 days. Thanks.
Old 08-14-2006, 01:15 PM   #19
I'm looking for a Sports Street Clutch for a KA.
Old 08-19-2006, 03:07 PM   #20
Thanks for the clutch Charles. It's freaking great.
SEO by vBSEO 3.6.0 PL2
