Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 09-16-2009, 01:23 PM   #1
Power fc party do it to it!
R/T Tuning Power FC Specials!
Hey gang R/T tuning is back with some great deals on Power FC’s . There isn’t a SR set up on earth that hasn’t been run on this industry standard ECU.
This is what Apex’i has to say about it.
The Power FC proudly stands as A'PEXi's answer to the constraints and limitations associated with most piggy-back style fuel controllers. The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path. From multiple point fuel and ignition control to VTEC engagement (Honda applications) and boost settings, the Power FC is capable of accommodating even the most demanding performance enthusiasts. Currently available exclusively through Power Excel Shops the Power FC replaces the factory ECU and controls all vital engine parameters (Off road use only, no OBD-II). Installation is as easy as replacing the factory ECU. (Some minor rewiring is required on select vehicles). The factory engine harness does not need to be replaced and all critical accessories such as air conditioning continue to function. By using the optional FC COMMANDER, the user can adjust and modify a wide range of settings. Since there is no need to upgrade ROM chips or modify ECU.
Pm me for crazy prices too low to post and Unit availability. Our shop is also open for locals to get tunes on our in ground Dyno-jet Dyno. The D-Jetro Set up is the same one we use on our shop car.
414AN008 Power FC 98-01 RB25DET ER34 Skyline
414AN012 Power FC 93-98 RB25DET ECR33 Skyline
414AN013 Power FC 93-96 SR20DET Silvia S14(Before Minor Change)
414AN014 Power FC 91-94 SR20DET 180SX RPS13(B/M/C) (Red Valve Cover)
414AN015 Power FC 93-96 SR20DET 180SX RPS13(Mid Minor Change)
414AN016 Power FC 96-99 SR20DET Silvia S14(After Minor Change)
414AN017 Power FC 96-99 SR20DET 180SX RPS13(After Minor Change)
414AN018 Power FC 99-02 SR20DET Silvia S15
414AN019 Power FC 93-96 SR20DET Silvia S14(B/M/C) D-Jetro
414AN020 Power FC 91-94 SR20DET Silvia S13/ RPS13 D-Jetro
414AN021 Power FC 93-96 SR20DET 180SX (Mid Minor Change) D-Jetro
414AN023 Power FC 96-99 SR20DET 180SX RPS13(A/M/C) D-Jetro
414AN024 Power FC 99-02 SR20DET Silvia S15 D-Jetro 415-X001
414AN025 Power FC 99-02 RB26DETT BNR34 Skyline GTR D-Jetro
414AN026 Power FC 89-99 RB26DETT BNR32/BCNR33 D-Jetro
414AN028 Power FC 99-02 RB26DETT BNR34 Skyline GTR
414AN029 Power FC 89-99 RB26DETT BNR32/BCNR33 Skyline
D-Jetro Parts:
When running a D-Jetro P-FC, the following parts are necessary
499-X001 Pressure Sensor
49C-A002 Pressure Sensor Harness 3 Pin (For Use on ***P/N: 414AN025, 414AN026, 414AN019)
49C-A004 Pressure Sensor Harness 5 Pin
N3A11845 Intake Temperature Sensor
415-XA03 Intake Temp. Sensor Harness
Optional Power FC Parts:
415-A001 Power FC Parts Boost Control Kit
415-A002 Power FC Parts Boost Control Kit
415-A008 Power FC Parts Boost Control Kit
415-A013 Power FC Parts Boost Control Kit
415-X001 Power FC Parts FC Commander
415-N001 Power FC Parts FC Commander
415-T001 Power FC Parts FC Commander
415-X910 Power FC Parts FC Commander PRO Software
Matt@R/Ttuning is offline   Reply With Quote
Old 09-16-2009, 01:30 PM   #2
Power Fc
414AN013 d-jetro and d jetro components with commander and boost controller shipped to 32821. If you could break down each item individually also( ex: FC $ ; boost controller $ etc.) thanks.
gorillas13 is offline   Reply With Quote
Old 09-16-2009, 03:42 PM   #3
Send a message via AIM to speedgod^s13
d-jetro with map conversion kit and controller to 96816.
speedgod^s13 is offline   Reply With Quote
Old 09-16-2009, 04:23 PM   #4
DirtyOldMan's Avatar
Location: NORCAL - SAC NOT Bayarea NOT So Cal NOT Anywhere Else! JUST SACRAMENTO
Send a message via AIM to DirtyOldMan
no RB20 awwwww
My WHITE WHEELS are 15x11 -46 STOP ASKING!
DirtyOldMan is offline   Reply With Quote
Old 09-16-2009, 04:26 PM   #5
414AN015 Power FC 93-96 SR20DET 180SX RPS13(Mid Minor Change) shipped to 95842
TEAM SKIDMARKS Carbon black S13 SR Coupe
2forty is offline   Reply With Quote
Old 09-16-2009, 04:27 PM   #6
rican_nick's Avatar
Send a message via AIM to rican_nick
Shipped to 30815.
also a seperate quote including the commander and boost kit.. i have to check and see if my current command and boost will work with the djetro (i think it would).
Nick O.
97 240sx
FS/FT:Work VSKF's
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 09-16-2009, 06:17 PM   #7
NMs14.5kouki's Avatar
how much for a boost control kit? s13 blacktop sr
NMs14.5kouki is online now   Reply With Quote
Old 09-16-2009, 06:58 PM   #8
& commander please to 91754
Thanks
Mike
s14_mike is offline   Reply With Quote
Old 09-16-2009, 09:25 PM   #9
crono72000's Avatar
Do u have one that is useable for the ca18det ??? If so how much for the power fc and commander shiped to 92021
Thanks !
93 2jz-gte S13 fastback
and 93 ca18det S13 coup
crono72000 is offline   Reply With Quote
Old 09-16-2009, 10:37 PM   #10
Boostedkouki's Avatar
Send a message via AIM to Boostedkouki
Shipped to Miami,FL. 33165.
Boostedkouki is online now   Reply With Quote
Old 09-16-2009, 11:37 PM   #11
also the commander and boost kit
price shipped to 85303
MeanS14 is offline   Reply With Quote
Old 09-17-2009, 01:43 AM   #12
holybushoffire's Avatar
Trader Rating: (-1)
Send a message via AIM to holybushoffire
Price shipped to 94591 on 414AN015 Power FC 93-96 SR20DET 180SX RPS13(Mid Minor Change) and all parts needed.
Thanks
"I am not good English, I like the drift"
CHINA DRIFT
SECRET SOCIETY
holybushoffire is online now   Reply With Quote
Old 09-17-2009, 09:06 AM   #13
D.Bo's Avatar
shipped to 70131
D.Bo is offline   Reply With Quote
Old 09-17-2009, 11:48 AM   #14
alcoholics go to meetings
xxchurroxx's Avatar
Send a message via AIM to xxchurroxx Send a message via Yahoo to xxchurroxx
414AN019 Power FC 93-96 SR20DET Silvia S14(B/M/C) D-Jetro shipped to Aiea, HI 96701 please
v-mount ftmfw.
xxchurroxx is offline   Reply With Quote
Old 09-17-2009, 03:14 PM   #15
power fc
power fc for sr20 redtop with commander and fc software shipped to 94109
hispeed is offline   Reply With Quote
Old 09-17-2009, 04:32 PM   #16
Send a message via AIM to JDMFLCL
boost control kit to 80224
also a quote for just the map sensor+harness for sr20
JDMFLCL is offline   Reply With Quote
Old 09-17-2009, 11:02 PM   #17
reccakun08's Avatar
414AN015 Power FC 93-96 SR20DET 180SX RPS13(Mid Minor Change) w/commander shipped to 20853
reccakun08 is offline   Reply With Quote
Old 09-17-2009, 11:32 PM   #18
Send a message via AIM to zer0cooL
414AN014 Power FC 91-94 SR20DET 180SX RPS13(B/M/C) (Red Valve Cover) price picked up locally, from jersey any possible discount with tune?
zer0cooL is offline   Reply With Quote
Old 09-17-2009, 11:59 PM   #19
HIGHWAY MONSTER
nurvcom's Avatar
Send a message via Yahoo to nurvcom
damm No RB20
Ripping up the Highway since 03
nurvcom is offline   Reply With Quote
Old 09-19-2009, 10:55 PM   #20
Can I please get a price quote for 414AN024 Power FC 99-02 SR20DET Silvia S15 D-Jetro 415-X001 and necessary d jetro parts and boost controller kit shipped to 89148.Thank you.
inFAMOUSbz is offline   Reply With Quote
Old 09-20-2009, 11:36 PM   #21
WangonwWarrior's Avatar
Location: Amerika24 alabama: Where if your not first..... your last
414AN029 Power FC 89-99 RB26DETT BNR32/BCNR33 Skyline shipped to 35007?
むねが、だいすきだ
WangonwWarrior is offline   Reply With Quote
Old 09-21-2009, 06:18 AM   #22
Separate quotes both with commander shipped to 90032
pogi_kep is offline   Reply With Quote
Old 09-21-2009, 07:58 AM   #23
the40sondec's Avatar
powa fc
price on 414AN013 Power FC 93-96 SR20DET Silvia S14(Before Minor Change) w/commander shipped to 23464?
the40sondec is offline   Reply With Quote
Old 09-22-2009, 09:04 PM   #24
Hi, I am looking for a D-Jetro for my 92' 180sx with the controller and boost selenoid (can you please break down each item) and also I dont know the right one to pick. I have a redtop SR20DET and willing to go 350 whp next season
Thanks
180sxqc is offline   Reply With Quote
Old 09-25-2009, 06:27 PM   #25
414AN015 ...or whatever Power FC is for the E5 ECU Blacktop
And
Commander!
28311
Moon Ill is online now   Reply With Quote
Old 09-26-2009, 09:51 PM   #26
SRPOWER 78's Avatar
i need pricing on 414an016 power fc 96-99 sr20det silvia s14 after minor change shipped to 75701?
SRPOWER 78 is offline   Reply With Quote
Old 09-26-2009, 10:11 PM   #27
price for redtop d jetro and map sensor kit shipped to 75088?
motorboater is offline   Reply With Quote
Old 10-01-2009, 01:57 PM   #28
ALL PM's responded.
ALL orders shipped.
Old 10-05-2009, 02:34 PM   #29
Hey brothers,
All orders shipped and PM's responded too. thanks a-lot for the orders!
Old 10-08-2009, 08:25 AM   #30
PM's Sent Got ya!
SEO by vBSEO 3.3.0
