Old 07-27-2012, 09:40 PM   #1
240sx_LokiS14's Avatar
Turbo Advice Little Bit Of Oil In turbo Pipe.
Is It Normal To Have A Little Bit Of Oil In Your Hot Pipe That Connects To The Turbo?
240sx_LokiS14 is offline   Reply With Quote
Old 07-29-2012, 02:10 AM   #2
240dream's Avatar
Mine did that for a little then stop my tuner said even brand new turbos can do that. But check shaft play side to side and in and out
240dream is offline   Reply With Quote
Old 07-29-2012, 07:46 AM   #3
Trader Rating: (26)
Feedback Score: 26 reviews
Is it a BB turbo? Do you have a restrictor or it if so? If not you may want to add one.
VVL S14 in the works...
jr_ss is online now   Reply With Quote
Old 07-30-2012, 02:03 AM   #4
Its The Stock t25 turbine turbo for the s13 sr20. n i have a oil catch can.
Old 08-02-2012, 07:20 AM   #5
Kingtal0n's Avatar
pictures of how the oil can is hooked up?
Some oil is normal, maybe 1% or less of one quart spread out along the first few inches of the hot pipe. It should not be a puddle. You do not want it in the intercooler. If it is a T-25 then the seals are probably going bad, and you may have the boost set too high which would lower it's lifespan even more.
please run 7psi
Old 09-08-2012, 09:53 PM   #6
Its Fine Now Sorry For the Late Rply
SEO by vBSEO 3.6.0 PL2
